griffin9959
Message 1 of 9
Broadband speed recovery after line fault.
14 days ago, after reporting no dial tone, an engineer came and replaced the cable between our house and the pole. Prior to the fault we had broadband download speeds into the region of 10Mbps.
I understand that following such an incident we need to wait for ten days in order for the connection to retrain and return to normal.
As I said at the beginning of this post 14 days have now passed and our speed has not recovered.  At this time our download speed is only 3Mbps to 5Mbps.  I have changed nothing on our side of the master socket and based on what the engineer said about the ten day retrain period, I would expect our speed to have recovered to 10 Mbps.
Any suggestions on how to proceed in order to get it download speeds back to where they were?
Thank you for any contributions.
8 REPLIES 8
Message 2 of 9
Re: Broadband speed recovery after line fault.
can you post stats from your hub?
run btspeedtester and when first test completes then run diagnostic test and post results   http://www.speedtest.btwholesale.com/
is there in line noise on home phone?
is connection stable or has there been resets/drops in internet connection?
griffin9959
Message 3 of 9
As requested please find below my hub stats and BTW Performance Test results.
The test results claim there is nothing wrong with the my speed but I note the IP profile is lower than it was prior to the engineer's repair.
Meanwhile there is no noise to be heard on the Quiet Line test.
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ71435442
Firmware version:
SG4B1000E016
Firmware updated:
14-May-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
1 Days, 10 Hours 23 Minutes 56 Seconds
Data rate:
912 Kbps / 5.41 Mbps
Maximum data rate:
1280 / 5632
Noise margin:
8.2 dB / 15.3 dB
Line attenuation:
35 dB
Signal attenuation:
18.3 dB / 35 dB
VPI / VCI:
0/38
Modulation:
G_992_5_ANNEX_A
Latency type:
Fast Path
Data sent / received:
475 MB Uploaded / 8778 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-52HQ
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-52HQ
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:0C:1C:D7
Software variant:
Boot loader:
7.33.1
FAQ
Results Image not loaded
1. Downstream Test:  -provides background information.
 Download  Speed
 4.64 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 4.64 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 4.77 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 1.02 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 1.02Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
Message 4 of 9
your profile is correct for your current connection speed but your noise margin at 15.3db is very high as normal is about 6db  however your connection time is only 1 day+ suggesting you are dropping connection unless that was a manual reset   for speed to improve you need a stable connection for the 10/14 days not just hub powered up
are you using test socket with a filter to see if that helps?
griffin9959
Message 5 of 9
I have not switched anything off or restarted anything since the engineers visit.
"are you using test socket with a filter to see if that helps?"
Are you suggesting I remove the face plate and plug my filter, to which my phone and hub are connected, into the test socket?
Message 6 of 9
as your hub is dropping connection it is stopping you getting a stable connection and your noise margin reducing and speed increasing
connecting to test socket with a filter will eliminate your faceplate and internal wiring as a problem   if hub continues to drop connection then you need engineer back
griffin9959
Message 7 of 9
Ok l I'll give it a go and monitor my Hub's up time
Message 8 of 9
once in test socket if you can post stats with 5 days stable connection and no speed improvement then post back and we can see if mods will help reset noise margin and get speed back - but stable connection first
griffin9959
Message 9 of 9
Will do. Thanks for your advice so far.
