Catch55
Message 1 of 3
Broadband speed slowed
My Broadband speed has slowed recently and around the time I was offered a contract extension., but nothing in my home has changed setup wise.
It was around 5.6 Mb/s and then slowed to 2.34 Mb/s, then come up to around to  3.73 Mb/s after I complained to BT, but I want it back to what it was.
I have checked all the cabling, did the quiet line test(Line was quiet), replaced the filters, ran the rounter off the master socket inside the socket, tried another rounter, tested it off a wired connection off two different laptops. Basically the speed coming into my flat has slowed.
What can I do?
2 REPLIES 2
Message 2 of 3
Re: Broadband speed slowed
can you post the stats from your router
if hh6 then advanced settings then technical log information
if hh5 then troubleshooting then helpdesk
enter your phone number and post results  remember delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
Catch55
Message 3 of 3
1. Product name:BT Home Hub
2. Serial number:+068340+NQ70812071
3. Firmware version:Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 24/05/17
4. Board version:BT Hub 4A
5. ADSL uptime:7 days, 20:48:04
6. Bandwidth:1212 / 4544
7. Data sent/received:2.1 GB / 45.7 GB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:No
10. 2.4 GHz Wireless network/SSID:BTHub
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub
15. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:a4:04:f7:b0:76:fa
20. VPI/VCI:0 / 38
21. Modulation:G.992.5 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:-
0
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8068.4201960.2Available----
VDSL Range B (Impacted)80632018.949Available----
G.fast Range A (Clean)3303305041.6330Planned----
G.fast Range B (Impacted)330293.25029274.3Planned----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6--5 to 7Available----
WBC ADSL 2+ Annex MUp to 6Up to 15 to 7Available----
ADSL MaxUp to 4--2.5 to 7Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date24-03-2018
