Message 11 of 13
Re: Broadband speed/tariff
That's the correct stats thanks
That shows you are on a fixed 576kbps connection but from the stats the attainable is about 5mb
You need mod help to get you of fixed connection and on to adslmax
I have asked mods to help
Moderator
Moderator
Message 12 of 13
Hi @M5355
Thanks for posting back with the info we asked for 😊
The checker for your line shows an estimate of 1Mbps however your Hub stats tell a different story.  From the stats you're definitely on a fixed rate service however there is potential to get you a connection speed closer to 5Mbps.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 13 of 13
Hi @M5355  I called earlier and left a brief voicemail sorry I missed you. I’ve checked and tried to get our suppliers to lift your broadband profile. I have tried to get you changed over to up to 8mb, Home 2000 and Home 1000 and they have rejected all orders. They have confirmed that they will only offer the Home 500 package on your line.
Sorry I am not able to bring you better news.
John
Community ModeratorJohnC
Kudos”Kudos”
