Message 1 of 4
Broadband speed way below what was promised.
I have tried everything but my average speed is 11mb but when  I changed over from Sky Broadband I was promised a minimum speed of 17mb.  My average with Sky was around 23mb.
I have moved the hub around to no avail.
Any ideas?
3 REPLIES 3
Message 2 of 4
Re: Broadband speed way below what was promised.
post hub stats if hh6 then advanced settings then technical log information
enter phone number and post results  remember delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
is you connection ok when using ethernet and only problem is wireless?
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
Message 3 of 4
@RosiePosy
What broadband package are you on, as I have assumed its just standard broadband, judging by the speed you have mentioned?
Moderator
Moderator
Message 4 of 4
Hi @RosiePosy,
Welcome to the Community and thanks for posting.
When you are running a speed test are you doing this on a wired or a wireless connection?
Can you also post the router stats?
Matt
