Do you mean
Newbie
Broardband speed has gone very very slow
[ Edited ]
Hi, I have been with BT about a month now and everthing has been fine with a 3meg plus connection until Friday last week when I lost my connection.
I rebooted the hub several times and then eventually I got a connection but since then it has been very slow.
My ADSL status is:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 01:32:04
Downstream:2.969 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.7 dB / 20.0 dB
Line attenuation (Down/Up):51.0 dB / 31.5 dB
Output power (Down/Up):18.8 dBm / 12.3 dBm
FEC Events (Down/Up):964 / 0
CRC Events (Down/Up):4 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):5 / 0
Error Seconds (Local/Remote):44 / 22
My online speed test result is:
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download  Speed
 87 Kbps
0 Kbps250 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 87 Kbps
 For your connection, the acceptable range of speeds is 100-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :3040 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
2. Upstream Test: -provides background information.
 Upload Speed
 346 Kbps
0 Kbps448 Kbps
>Upload speed achieved during the test was - 346 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
Please help. Thanks
Tony
Re: Broardband speed has gone very very slow
[ Edited ]
Hi welcome to the forums
Your slow download speeds are being caused by a low IP profile this has been caused by disconnections /restarts of your hub you need to leave powered up 24/7 with no restarts or disconnections for the next 3/5 days while the exchange equipment see your line as stable again your ip profile will then rise again along with you download speed just a matter of waiting
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
Thanks for the quick response and I will give it a few days and see what happens.
Cheers.
if it has not risen after 5 days then you will need intervention by the forum mod team post back then and we can give contact details
Try a Search
Newbie
Hi, turns out that I had a line fault which has now been corrected see speed test below:
FAQ
 Download  Speed
 2289 Kbps
0 Kbps4000 Kbps
 Download speedachieved during the test was - 2289 Kbps
 For your connection, the acceptable range of speeds is 1200-4000 Kbps.
 Your DSL Connection Rate :3008 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 2500 Kbps
 Upload Speed
 346 Kbps
0 Kbps448 Kbps
line must have been reset and your profile is now correct for your connection speed
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
