Rsadan
Message 1 of 6
Bt master wiring a new slave from it
I have a master socket thibk its the net 5, i have the service provider cable coming in to terminals a and b, i have ran a cat5e cable from terminals 2 and 5 in the master pushdown terminals to a new slave which is terminated in 2 and 5, 2 is a solid blue conductor and with and blue in terminal 5. I plug the phone in but its wont work, its just says check the line on the phone, am i doing something wrong?
5 REPLIES 5
Message 2 of 6
Re: Bt master wiring a new slave from it
Welcome to this user forum.
Who provides your phone and broadband connection?
Message 3 of 6
Have you re-assembled the master socket otherwise the extension won't work. Are you sure you have fully pushed the wires in using a proper punchdown tool.
Rsadan
Message 4 of 6
Hi thanks for the reply, yes i have ive used my bt punch down tool, i plug the phone in the bt master test socket and it works but wont at the slave, its like the 2 and 5 terminals aren't working,
Rsadan
Message 5 of 6
Bt is the provider
Message 6 of 6
@Rsadan wrote:
Bt is the provider
Just wanted to make sure that the forum was not giving advice which may be incorrect for your provider.
