Pembo
Message 1 of 8
Call Center Dead-end for Gaming Issues
Hey Guys,
Been a while since I've posted but I'm having some major issues with my Internet again and the call centres are about as much use as a chocolate firegard.
Basically I'm have big problems playing online games. This has always been a bit of problem intermittently but recently its been impossible.
Speedtest.net is reading my PING at over 600 and I've lost 1mb download speed so I'm now down to 1.5mb
My usual speeds are around 60ping and 2.5 download.
Like I say, I've called BT about this and they are telling me there is no problem with my broadband and Premier Calls tell me that there is no fault on the line so I'm stuck between a rock and a hard place as you can imagine.
I'm using a BT home hub 3.0 and I've just found port forwarding using http://192.168.1.254 but I doubt this can help me with a ping of 600.
Any help would be greatly appreciated.
Cheers,
Simon
7 REPLIES 7
Message 2 of 8
Re: Call Center Dead-end for Gaming Issues
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Could you also please post a traceroute to BBC.co.uk
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Pembo
Message 3 of 8
Thank you for the quick responce,
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 01:24:41
Downstream:2,987 Kbps
Upstream:612 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.0 dB / 6.3 dB
Line attenuation (Down/Up):60.0 dB / 33.9 dB
Output power (Down/Up):18.5 dBm / 12.0 dBm
FEC Events (Down/Up):58 / 279
CRC Events (Down/Up):9 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):22 / 0
Error Seconds (Local/Remote):0 / 0
Pembo
Message 4 of 8
The problem I'm facing is PING spikes http://www.speedtest.net/my-result/2944292379
Pembo
Message 5 of 8
I could not hear any noise on the line but coincidentally the problem seems to be calming down since I started this thread.
http://www.bbc.co.uk/
Message 6 of 8
could you please do a ping test using command prompt to bbc.co.uk also a traceroute
Pembo
Message 7 of 8
Hi John,
Message 8 of 8
The ping times are about correct for an interleaved connection
