bobby67
Message 1 of 4
Can't get ADSL2+
Our local exchange in Winchburgh has been upgraded to ADLS2+ allowing speeds of up to 17Mbps. But when I go onto dslchecker.bt.com it still shows that I can only get speeds of up to 7Mbps. Our friends in the street next to ours can get ADSL2+ at 17Mbps according to the dslchecker. Why would this be?  😞
This is what I get
And our friends who live one street away get
3 REPLIES 3
Message 2 of 4
Re: Can't get ADSL2+
most likely because their lines are shorter length to the exchange then yours are
bobby67
Message 3 of 4
What I don't understand is our friends house is only 40 feet away and they can get the increased speed. I would have thought that I would have seen some kind of gradual increase/decrease rather that a clear cut 'Yes you can get it or' 'No change'.
Boudges
Message 4 of 4
Unfortunately no two lines are the same. This is an example of that There are just too many variables that come into play 😞
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
