ljm
Expert
Message 1 of 10
Cannot OPT OUT of BT Wifi
Hello everyone,
Following a Firmware Update, and a Factory Reset which i did, i was auomatically Opted In to BTWifi.  This always happens.  I went to the BTWifi Status Page and Opted Out cos i don't want it.
However, 48 hrs. has passed (which they say you should give to disable it) and my Hub Manager etc is still showing ACTIVE.
I remember once seeing a post about this issue and someone suggested Opting In again and then back Out again but the problem is that on the Status Page there is no option to do this.  There is only an option to Opt Out which i've already done............ no option to Opt back in again to try the suggestion.
God knows why BT make it so difficult!!  Where do i go from here please?
9 REPLIES 9
Dippu
Message 2 of 10
Re: Cannot OPT OUT of BT Wifi
If you Opt In  (Register for BT Fi) in the follwoing link: https://www.bt.com/wifi/secure/index.do?s_cid=con_FURL_btwifi&utm_source=ATL&utm_medium=FURL&utm_con...
and then give it 24 hours and then Opt out using Check My Status (top box), will see an option to Opt out once you press Check My Status.
This has worked for me a few time and everytime it has taken about 48 hours.
graeme2507
Message 3 of 10
Hi @Dippu
Do you know whether I'd be able to use BT Wi-Fi when I'm out and about if I've opted out (i.e. turned it off on my router).
I want to make sure the low speed/bandwidth I get at home aren't impacted by sharing what little there is with someone else.  Also, I seem to have very high data usage figures considering how much I use my broadband and hopefully opting out will eliminate any use that isn't my own.
Cheers.
Dippu
Message 4 of 10
If you Opt out then you will not be able to use BT WiFi when out and about. If you want to use this facility then one way around it is by using a cheap third party router and stay Opted in.
graeme2507
Message 5 of 10
Thanks @Dippu - I thought as much.
Cheers
ljm
Expert
Message 6 of 10
Thanks very much Dippu. Will try it out .
ljm
Expert
Message 7 of 10
Hi Dippu,
Just to let you know it's worked, thanks!
beetjam99
Message 8 of 10
I don't think there is any real long term way of controlling this frankly.
I enjoyed at least 2 web chats to get 'BT Wi-Fi' disabled on my own Home Hub, both agents promised it would be done within 24 hours, this is after waiting the 30 days since opting out - nothing has changed ever.
Today my router has had a new firmware, still showing I am opted in to 'BT Wi-Fi' - shame they can't include an option to simply untick it in the router admin page right? There is no reasonable or logical excuse other than they just don't want you to disable it.
The only real solution is to use a different router I suppose.
I am still shocked by their agents lack of any real interest in the issue, it seems to take them 4-5 minutes to look at this, look at that, then another 5 minutes to connect into the router and make the change.. which doesn't take effect.. ye ok.. more like they are juggling 3 customers at the same time and you dare to ask about that silly setting in your BT router.. I'm sure they'll just hide the 'BT Wi-Fi' item in the admin page next to stop people from asking.
They sure are amusing.
J
Distinguished Guru
Message 9 of 10
@graeme2507wrote:
Hi @Dippu
Cheers.
Sorry I'm late replying, but I'm afraid you've slightly misunderstood how BTWifi works.
It does NOT count towards any usage limit you have. Also it shouldn't impact on your speeds that much, especially if you're using it - though some have indicated it might under some condition.
Moderator
Moderator
Message 10 of 10
@beetjam99 Please send me over your details using the contact the mods link and we'll be happy to help you opt out of the BT Wifi service. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
