spruzes
Message 1 of 18
Capped broadband speed after major fault on line
Hello, I'm a long-term BT customer but a recent BT Broadband customer, using a BT Home Hub 3 type A. Since the fault on my line has been fixed, my broadband download speed appears suspiciouly constant at 1152 - see below. I write 'suspiciously' as, whilst the fault was being fixed, my Broadband speed (when available) dropped as low as 240-ish but as high as 1890+ so my line is clearly capable of delivering a higher throughput than I'm getting.
My neighbour's Broadband (also with BT, also using a Home Hub 3) appears faster than mine, around twice as fast when we both recently downloaded the same iPhone update, but I haven't done a speed test on his line.
It appears from other posts that BT cap broadband speed after repeated disconnects (caused by my line fault that BT have now fixed), but don't seem to quickly uncap the broadband top speed.
Any ideas?
1. Product name:BT Home Hub
2. Serial number:---- removed for posting ----
3. Firmware version:Software version 4.7.5.1.83.8.57.1.3 (Type A) Last updated Unknown
4. Board version:BT Home Hub 3.0A
5. ADSL uptime:10 days, 22:41:21
6. Bandwidth:448 / 1152
7. Data sent/received:0.1 / 2.4
8. Broadband username:bthomehub@btbroadband.com
9. BT FON:No
10. Wireless network/SSID:---- removed for posting ----
11. Wireless connections:Enabled, (802.11 b/g/n (Recommended)) 20 MHz
12. Wireless security:WPA and WPA2
13. Wireless channel:1
14. Firewall:Default
15. MAC Address:---- removed for posting ----
16. VPI/VCI:0 / 38
17. Line profile:Interleaved
17 REPLIES 17
spruzes
Message 2 of 18
Re: Capped broadband speed after major fault on line
More ADSL information from the Hub's management console:
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):14.5 dB / 19.0 dB
Line attenuation (Down/Up):42.3 dB / 26.0 dB
Output power (Down/Up):16.7 dBm / 11.9 dBm
FEC Events (Down/Up):4559529 / 1077
CRC Events (Down/Up):490039 / 1042
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):490579 / 493
Error Seconds (Local/Remote):20472 / 1195
Message 3 of 18
Hi could you also post the connection time and connection speed from your adsl stats
spruzes
Message 4 of 18
Hello - Both are in my first post - but here again...
Message 5 of 18
Hi
I am sorry to see you are having problems
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
spruzes
Message 6 of 18
I contacted the forum mods, and they are indeed on the case, so thanks. I will keep you posted as to the outcome.
spruzes
Message 7 of 18
Well, so far my router has behaved oddly twice - it slows right down (e.g. 15-20 secs to display event log page), shows that broadband is connected - yet all websites timeout. The WiFi network remains up, so it's not a total HH3 router crash.
This odd behaviour lasts for about 30 mins, then all comes back, and line speed has changed. It got as high as 2.1Mbps but has since sunk down to 1.781 (see below).
It would be great to get the 2.1Mbps back... I notice the latency type changed from 'fast' to 'interleaved' too.
What sort of speed should I be expecting?
Simon.
Connection Information
Line state:Connected
Connection time:0 days, 03:58:54
Downstream:1.781 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):4.1 dB / 19.0 dB
Line attenuation (Down/Up):42.4 dB / 27.0 dB
Output power (Down/Up):18.0 dBm / 11.9 dBm
FEC Events (Down/Up):6550591 / 823
CRC Events (Down/Up):413795 / 814
HEC Events (Down/Up):3618820 / 3570
Error Seconds (Local/Remote):15143 / 2425
Message 8 of 18
check your possible speed on a good line here
check speed
are you connected to the master or preferably the test socket?
Message 9 of 18
You have a very high number of errors showing for such a short connection time using the test socket will eliminate any internal wiring problems
spruzes
Message 10 of 18
Unfortunately I am using the test socket... and the speed has now dropped to 1.5 Mbps
