Voucher
Message 1 of 30
Change from ADSL to ADSL2+
Change from ADSL to ADSL2+ We have 2 lines into our house, both with BT - the one is on ADSL and the other on ADSL2+.
I would like both on ADSL2+.  Can this be done?
Any help will be appreciated.
29 REPLIES 29
Message 2 of 30
Re: Change from ADSL to ADSL2+
can you post stats from line on adslmax please
Voucher
Message 3 of 30
Voucher
Message 4 of 30
Message 5 of 30
@Voucher wrote:
you are already on ADSL 2+
Voucher
Message 6 of 30
I know that one is on adsl2+ it is the first one i want changed.
Message 7 of 30
From the tplink stats the upgrade to adsl2 will make little improvement to the down speed but should give maybe 100% more up speed
i have asked mods to see if they can help you and they will post here with link
Voucher
Message 8 of 30
Thank you but where we live every megabyte counts enormously. I sincerely hope they can help.
Moderator
Moderator
Message 9 of 30
Hi @Voucher
Welcome to the community and thanks for your posts.
We can check about the possibility of upgrading your line to ADSL2(+).  It shouldn't be a problem as you have ADSL2 on your second line but I'd like to double check from here before promising anything.
It doesn't look like there will be much of a change to your downstream speed but you'll see an upstream speed improvement as the upstream speed on ADSL2(+) is up to 1meg.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Voucher
Message 10 of 30
Thank you have filled out the contact form.
Much appreciated.
