Prh66
Message 1 of 10
Connecting at lower speed
Hi
As of the last few, weeks my connection has slowed, i used to connect at around 12mbps now it is down to around 9mbs, i have noted that BT have been doing some work in my street, could they have inadvertantly caused my internet speed to drop?.
Paul
9 REPLIES 9
Message 2 of 10
Re: Connecting at lower speed
Hi Welcome to the community forums
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband
in the call are you connected to the test socket using a new filter
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
if using the hub 6 locate the information page in the hubs advanced settings and post the results back
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
once you have posted the information asked for then the community members can help you more
Thank You
Prh66
Message 3 of 10
Hi
Quite line test is fine
Speed tests below
Cheers
Paul
Hub lines
07:17:32, 09 Sep.( 106.700000) DSL noise margin: 6.00 dB upstream, 13.70 dB downstream
07:17:31, 09 Sep.( 105.790000) DSL line rate: 1112 Kbps upstream, 9400 Kbps downstream
Message 4 of 10
once you can maintain and post back 3/5 days stable connection of your hub the forum mods can arrange a noise margin reset which will increase your speed back towards the speed you had before
Prh66
Message 5 of 10
Hi
Will post back in three days, many thanks
Paul
Prh66
Message 6 of 10
Hi
As asked for..
3 days connected
Cheers
Paul
Message 7 of 10
I have asked a forum moderator to help you they will post their contact link here
Moderator
Moderator
Message 8 of 10
Hi @Prh66,
We'll take a look into it for you. You can reach us by clicking on my user name and then on contact the mods. We'll get back in touch with you over the next 5 working days.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Prh66
Message 9 of 10
Thanks.
Moderator
Moderator
Message 10 of 10
Hi @Prh66,
I'm glad I was able to get this sorted for you. Thanks for letting me know. Post back if you have any other problems and we'll be happy to help.
Cheers
David
Community ModeratorDaveM
Kudos”
