ggbrown73
Message 1 of 11
Connection Really Poor
Hi folks,
I have been with BT Broadband for well over 2 years now and am using the HomeHub 3 at the moment. This past month the connection has been terrible. Both on wireless and with the cable plugged in to the laptop.
Granted we have a lot of stuff connected to the hub at times but even when it's just a couple of things it is still very "laggy"
Below is my ADSL Status as of a few minutes ago:
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:1 days, 04:22:06
Downstream:4 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.7 dB / 17.0 dB
Line attenuation (Down/Up):54.0 dB / 30.0 dB
Output power (Down/Up):19.6 dBm / 12.5 dBm
FEC Events (Down/Up):111960 / 1232
CRC Events (Down/Up):41 / 4
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):400 / 1
Error Seconds (Local/Remote):31 / 7
10 REPLIES 10
Message 2 of 11
Re: Connection Really Poor
there is nothing obvious from your hub stats your connection speed is correct for your attenuation
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
ggbrown73
Message 3 of 11
Thank you. I will wait until later this evening (so the kids aren't online) and run the speedtest. Will post the results then.
Message 4 of 11
can you also connect your hub to the test socket as shown as well please
fred1945
Newbie
Message 5 of 11
I have the same they are bad and you cannot get them to solve it I have had it for 11months of useless service, good luck I am going to you and yours as I have had enough of calls and bull from them I get .2 .5
Regards
Fred
Message 6 of 11
fred1945
There is no obvious problems with this posters connection this is why he has been carry out some extra checks
a reply has been posted on your post
ggbrown73
Message 7 of 11
Ok, I ran the speed test and here are the results
FAQ
<script type="text/javascript">// paintProgressAndMessageOnBar(100,"The test has successfully completed"); // </script>
    1. Best Effort Test:          -provides background     information.
Download Speed
2.45 Mbps
0 Mbps
7.15 Mbps
      Max Achievable Speed
Download speed              achieved during the test was       - 2.45 Mbps
      For your connection, the acceptable range of speeds              is 0.6 Mbps-7.15 Mbps.
      Additional Information:
      Your DSL Connection Rate :4 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
      IP Profile for your line is - 3 Mbps
    If you wish to discuss these results please contact your Broadband Service     Provider.
If you are experiencing problems     with specific applications, servers or websites please contact your     Broadband Service Provider for assistance.
Your test has completed please     close this window to exit the performance tester.
We have identified that you have     additional services enabled on you broadband line, please click continue to     run advanced service tests.
FAQ
<script type="text/javascript">// paintProgressAndMessageOnBar(-1 ,"Last Test Required"); // </script>
  1. Assured Rate Test:      -provides background   information.
Download Speed
0.45 Mbps
0 Mbps
0.6 Mbps
Download speed          achieved during the test was     - 0.45 Mbps
    For your connection, the acceptable range of speeds          is 0.58 Mbps-0.6 Mbps .
    Assured Rate IP profile on your line is - 0.6 Mbps
  This test was not conclusive and further testing is required.This might be   useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further   tests,please click on 'Continue' button.If not, please close the window using   'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you   are unable To understand the test results.
I tried to run the Tap3 test but got an error message saying something about not running it on a bthub!!!!
ggbrown73
Message 8 of 11
Sorry for the messy layout, I just copied and pasted direct from the browser.
Message 9 of 11
your profile is low and should be 3.5mb for your connection speed.  just stay connected 24/7 and profile should rise in 3/5 days maybe sooner
ggbrown73
Message 10 of 11
Thanks for the prompt reply. I noted that the results mention an atainable speed of 7mb on the line. Is this possible?
