alythe87
Newbie
Message 1 of 4
Connection dropping on wired only
Hello,
I am having a problem with my Home Hub 2 connection.
2 Days ago, my connection started dropping every 30 seconds or so, and is still doing it. When I -t ping google.com, every 20 seconds or so, the connection drops for around 3-5 seconds. This continues for aslong as I keep pinging. I am on a wired connection.
The strange thing is, the wireless connection is absolutely fine. There are no drops in connection at all, nor are there any other problems. The issue is soley on the cabled connections.
  • I have tried all the ethernet ports on the modem
  • I have tried the test socket (under the cover of the phone line socket on the wall)
  • I have tried different ethernet cables
  • I have tried different PC's and laptops
  • The wired connection drops consistently every 20 seconds, for 3-5 seconds
  • This has been happening a couple of days
  • The Home Hub firmware is up to day
  • My wireless card(s) drivers are up to date
  • I have tried with and without anti virus/security enabled
I am reluctant to think this is a phone line problem, as that would not explain why the wireless connection works fine. I am tempted to think I have a faulty Home Hub.
Any suggestions would be very, very welcome,
Thank you
Andrew
alythe87
Newbie
Message 2 of 4
Re: Connection dropping on wired only
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 0:06:34
Downstream 6,048 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Fast
Noise margin (Down/Up) 6.2 dB / 12.0 dB
Line attenuation (Down/Up) 22.0 dB / 14.5 dB
Output power (Down/Up) 19.8 dBm / 12.1 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 1 / N/A
HEC Errors (Down/Up) N/A / 0
Error Seconds (Local) 1
alythe87
Newbie
Message 3 of 4
My apologies, problem sorted with a simple reset of the router.
Message 4 of 4
Hi glad all is sorted now sometimes a reset works miracles
