Moderator
Moderator
Message 11 of 13
Re: Connection keeps dropping
Hi mjones494,
Thanks for posting. I can look into this for you if you wish. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile. Once I have the details we'll take it from there.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
mjones494
Message 12 of 13
thanks for the reply, ive completed&sent the form.
Message 13 of 13
The mods will normally contact you personally contact you personally within 3/5 days after you reply to their contact. Link
