dephead2004
Message 1 of 55
Connection loss overnight
Over the last 3 nights I restart the PC in the morning to find that there is a loss of BB connection. I go through the rigmarole of rebooting HH4. Also password was changed at first install but now not recognised and I am 3 minute lockout. I have resolved this by factory reset. Connection still drops.
Firmware updated on 23/7/13 to 4.7.5.1.83.8.130.1.10.
Can anyone suggese anything please? There were NO issues on the HH£ which the HH4 replaced w/b 15/7/13
54 REPLIES 54
Moderator
Moderator
Message 2 of 55
Re: Connection loss overnight
Hi dephead2004,
Welcome and thanks for posting. Are the problems wireless or cable? Do the lights on the hub change? You might find the answer here but if not give us much information as possible and I’m sure we’ll be able to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Welsh
Message 3 of 55
Hi Both,
I was just about to start a thread on this when I saw this.
Unfortunately, I have suffered nothing but problems since switching over to BT from Sky. I have had a multitude of issues which I won't go into, however, I am now at a similar point as the OP - ie. I have a homehub 4 that needs reseting every morning as it drops it's speed by half every night. I go to bed with a 3.2mb connection and I wake up with between 1.5 and 1.9mb - I reset it and it returns to 3mb.
I have exhausted all of BT's levels of help - I have basically been told that they have 'never heard of anything like this' and I have been faffed-off with a  'R.A.I.N. or S.H.I.N.E.' explanation that they cannot do anything about - basically, it means there is some sort of power-surge that effects my router intermittently - which is frankly, a tech term for 'we've no idea' - Funnily enough, my Sky BB never suffered such issues and I'm somewhat regretting my switch-over now..
Having googled the issue, it seems there is a ton of people out there experiencing similar things, so I find it pretty hard to accept that I'm some sort of 'freak case' as I've been led to believe.
Anyway, has anyone got any ideas that might help me that BT couldn't provide? - I have read a few things, ie. that the 'HH doesn't like a wired and wireless connection at the same time'...'The only way to resolve this issue is buy a different router' is this really true?
I am worried that the constant resets will translate as a line issue to the BT servers and my already snail-speed line will be slowed down even further! Please help!
Welsh
Message 4 of 55
Anyone? :smileysad:
Message 5 of 55
try quiet line test first to see if any noise  dial 17070 option 2  should hear nothing and best with corded phone from test socket.. if cordless dull hum is normal
as you have a HH4 there a few stats available to help so can you run btspeedtester and when first test completes can you run diagnostic test and post results
btspeedtester
Welsh
Message 6 of 55
Thanks Sage,
I'm in work for the next couple of hours but I will post the stats by late afternoon.
Welsh
Message 7 of 55
whenever it suits you  there is always someone around
Message 8 of 55
i do not know were you have heard that the HH 4 does not like a wired and wireless connection at the same time but whatever the source was it is total rubbish and there is no such problem
dephead2004
Message 9 of 55
Hi David M,
The light is blue (as it should be) however it is not doing what a blue light should ie connect to the internet. On reboot it goes through the usual start up colours. The loss of password comes when I try to look at the advanced settings. You wouldn't know it was a problem unless you wanted to do that. Oh and, until reboooted, connect to the internet 🙂
dephead2004
Message 10 of 55
BT Speedtester details, as you can see we are well connected when it works:
 Download speedachieved during the test was - 1.98 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.72 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
quiet line test: I'd say good eg a bee a v v long way away, no crackles and this was a wirelss handset.
I think the problem began after the firmware update on 23/7/13. Can't be sure as had not had it long enough befor ethe update
Does that help?
