Welsh
Message 21 of 55
Re: Connection loss overnight
Cheers John, it seems to be working now, but it doesn't display my profile, just some bar charts with speed info on etc and the message as stated in my previous post. Could it be to do with Firefox? I'll try again using IE...
Welsh
Message 22 of 55
...nope, it looks just the same. Have BT changed something?
Message 23 of 55
just post the bar charts and all details shown the IP Profile is there
Welsh
Message 24 of 55
Thanks John, here you go:
1. Best Effort Test:  -provides background information.
Download  Speed
2.74 Mbps
0 Mbps    4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 2.74 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 2.79 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.37 Mbps
0 Mbps    0.45 Mbps
Upload speed achieved during the test was - 0.37Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Welsh
Message 25 of 55
...I've also just noticed another thread that talks about random diconnections early in the morning,
http://community.bt.com/t5/BB-Speed-Connection-Issues/Slow-Broadband-due-to-losing-connection-daily/...
Could ithese issues be connected and point to a router/firmware problem??
Message 26 of 55
There is nothing wrong with your
IP profile
Message 27 of 55
The earlier post and the link refer to home hub 3's not the HH 4
Welsh
Message 28 of 55
And it has happened again... I went to bed with a hub measurment of 3.16mb and I've woken up this morning with a reading of 1.8mb - This reading will not change until I reset my router, then it will bounce back up to 3mb+. What is going on? This is getting extremely frustrating now!
Could a Mod possibly look into this? I am finding it difficult to accept that BT cannot do anything about this issue when I retained a perfectly good connection and consistent speed with a competing operator - as many did, I switched because of BT Sport.
Here are the new readings from the wholesale test (note it has changed the 'acceptable range' and 'Max achievable speed' from 4mb to 2mb - this will change back when I reset the hub):
    Download  Speed
    1.65 Mbps
0 Mbps    2 Mbps
 Download speedachieved during the test was - 1.65 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 1.66 Mbps
    Upload Speed
    0.38 Mbps
0 Mbps    0.45 Mbps
Upload speed achieved during the test was - 0.38Mbps
Welsh
Message 29 of 55
Can anyone shed any light on the above? I really want to get this fixed before my repeated resets start to cause even worse problems... Smiley Sad
Message 30 of 55
The modish,old be in touch when they read the post
