ed-h
Message 1 of 9
Consistently slow broadband speeds - IP Profile of 1.97 Mbps
For a few months now I've been getting consistently slow broadband speeds - between 1 and 2 Mbps download and 0.02 to 0.03 Mpbs upload speed. When I first moved to BT at the current address I was getting at least 4 to 6 Mbps download without any problems. It's got to the point where the broadband is unusable if there is more than one person online in the house so I'm now considering my options, but thought I'd see if anyone here can help before I move / upgrade.
Some details that might help:
  • I'm circa 750m from our exchange (in a straight line)
  • I'm using a BT Home Hub 4
  • Hub is connected to the main (only!) phone socket in the house which is right by the front door
  • I'm using an ADSL splitter (the one that came with the hub)
  • I don't have a home phone (only have the line for broadband) so can't run a quiet line test
I'm also attaching screenshots of speed test results, diagnostics and router stats.
I noticed that the IP Profile for our line is 1.97 Mbps which seems very low given that in theory I should able to get 7-8 Mpbs.
Any help gratefully received!
Ed
Broadband availability
Speed Test Diagnostics
8 REPLIES 8
Message 2 of 9
Re: Consistently slow broadband speeds - IP Profile of 1.97 Mbps
try connecting with a new filter to the test socket if you have an NTE5 master  test socket.jpg
try 1 factory reset of the hub by pressing the recessed button on back and holding until lights flash
then repost your stats
Message 3 of 9
if using a hub 4 locate these lines located in the hub logs
Lines should look like this you can locate them by using the drop down menu and select WAN
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Message 4 of 9
without a phone you can't tell if you have a line noise problem which is causing the low connection speed. you can get a cheap corded phone for about £5. checking your phone line for noise can help you avoid paying £129.99 for an engineer callout if the problem is in your home or with your setup
ed-h
Message 5 of 9
Thanks for the replies.
I've got a non NTE5 master socket so no test socket for me to try, but I have tried a different filter + a hard reset of the hub which doesn't seem to have made a difference. Worth nothing that the diagnostics step of the speed test won't complete due to an error so I can't get all of the details this time round.
Screen shots of the router stats and relevant logs are attached.
Happy to go out a pick-up a cheap phone if required. Let me know if there is anything else I can try before that.
Thanks.
Speed Test Results 27.01.JPGSpeed Test Diagnostics 27.01.JPGRouter Stats 27.01.JPGRouter Logs 27.01.JPG
Message 6 of 9
looks like a line problem but without quiet line test cannot tell if you need a phone enineer to fix a noise problem or a broadband engineer - but certainly one of them
ed-h
Message 7 of 9
OK, thanks. I'll get a phone and then comment back once I've run the quiet line test.
ed-h
Message 8 of 9
So I went out and bought a phone, plugged it in and... nothing. Not even a dial tone. So this looks very much like a line fault. I tried running the online phone line test but it just knocks out my connection each time, so I'll give BT a call instead.
So I guess this thread can be closed. Thanks to those who replied.
Message 9 of 9
it only shows the importance of a phone to be connected as it shows up possible faults quickly
