Message 11 of 18
Re: DLM
As far as I'm aware it will just reset it to the 6dB figure, I don't think it is possible for the mods to set it to any other value.
Message 12 of 18
Re: DLM
Thanks for the reply, so they couldn't reset the snr to be 18 which would lower the connection speed.?
Message 13 of 18
Re: DLM
I don't believe so, no. The Billion trick certainly works though, before our village was enabled for FTTC I used a Billion to squeeze the last bit of speed out of an exceedingly long line.
Message 14 of 18
Re: DLM
It would help if you explained what you gaming problem is as changing speeds should not really affect gaming also can you post the stats from your Router/hub
Message 15 of 18
Re: DLM
The problem with my online gaming is for example, yesterday earlier in the day Battlefield 1 was playing perfectly smooth at the 8.0 mb profile, good hit detection and no jitter etc.
The line reset in the afternoon to the 8.8 profile. and immediately the poor hit detection / jitter issue started and this has been the same issue each time the line is reset.
They eventually bring the profile back down again to the lower level after a few weeks and gaming is noticeably better.  At times they have raised the profile  to almost 10mb D/Load and it seemed worse at the higher levels. (Not sure how to post stats HH4).
If there is no way to prevent the line resetting then I have to either live with it or go with the new router suggestion, thanks for your help I appreciate it.
Message 16 of 18
Re: DLM
I suspect the OP's line is operating on the boundary between 8.8M and 8.0M. DLM will try to maximise the speed and try to operate at 8.8M until the error rate, which will affect gaming due to the need to retransmit all the time, passes the threshold and reduces the sync speed to 8.0M where the error rate decreases once again and the cycle begins again. Setting the SNRM to, say, 9dB or even 12dB will stop the errors.
Message 17 of 18
Re: DLM
Get a billion
Message 18 of 18
Re: DLM
Thanks for your help everyone, I now understand the issue better and also what the possible options are if I want to pursue a new routter.
