dephead2004
Message 1 of 21
Daily Dropouts
I have a BT HH4 and a BB connection of around 1.7Mbs downstream.
The problem is daily dropouts requiring a hub reboot. The dropouts occur in the morning usually at around 0900 altrhough sometimes later in the morning. There is only one per day
I have contacted BT and have had the hub replaced with another HH4. We have tried other ports on the hub
The hub is connected to the Openreach master socket directly into the upper socket. No other phone is connected to the lower socket.
The PC is hardwired by LAN although there are other wireless and wired devices on the system.
Today I recieved a call back from BT in Chennai. They ran more tests and declared that it was a sync problem between the hub and the exchange. There was nothing more they could do and it was normal for the hub to disconnect daily.
I said that I thought this was strange as most customers would not be willing to reboot their hub almost daily as I have to.
I wonder if anyone can verify these statements. All help would be appreciated.
Here is the log from the dropout this morning occuring at 0630 today with some earlier activity? PC was switched on at 0615.
07:30:19, 03 Nov.
( 130.040000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
07:30:19, 03 Nov.
( 130.030000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
07:30:10, 03 Nov.
( 120.900000) PPP IPCP Receive Configuration ACK
07:30:10, 03 Nov.
( 120.880000) PPP IPCP Send Configuration Request
07:30:10, 03 Nov.
( 120.870000) PPP IPCP Receive Configuration NAK
07:30:09, 03 Nov.
( 119.780000) PPP IPCP Send Configuration ACK
07:30:09, 03 Nov.
( 119.780000) PPP IPCP Receive Configuration Request
07:30:09, 03 Nov.
( 119.200000) PPP IPCP Send Configuration Request
07:30:09, 03 Nov.
( 119.190000) WAN operating mode is DSL
07:30:09, 03 Nov.
( 119.190000) Last WAN operating mode was DSL
07:30:07, 03 Nov.
( 117.740000) PPPoA is up -​ VPI: 0, VCI:38
07:30:07, 03 Nov.
( 117.730000) CHAP authentication successful
07:30:07, 03 Nov.
( 117.490000) CHAP Receive Challenge
07:30:07, 03 Nov.
( 117.490000) Starting CHAP authentication with peer
07:30:07, 03 Nov.
( 117.490000) PPP LCP Receive Configuration ACK
07:30:07, 03 Nov.
( 117.470000) PPP LCP Send Configuration Request
07:30:05, 03 Nov.
( 115.800000) PPP LCP Send Configuration ACK
07:30:05, 03 Nov.
( 115.800000) PPP LCP Receive Configuration Request
07:30:04, 03 Nov.
( 114.470000) PPP LCP Send Configuration Request
07:02:12, 03 Nov.
wlan0: STA 78:40:e4:0b:72:f2 IEEE 802.11: Client associated
07:02:12, 03 Nov.
wlan0: STA 78:40:e4:0b:72:f2 IEEE 802.11: Client disassociated
07:02:11, 03 Nov.
07:01:01, 03 Nov.
07:01:01, 03 Nov.
wlan0: STA 44:e9:dd:75:36:2e IEEE 802.11: WiFi registration failed
06:33:17, 03 Nov.
wlan0: STA 10:a5:d0:08:76:af IEEE 802.11: Client disassociated
06:33:17, 03 Nov.
wlan0: STA 10:a5:d0:08:76:af IEEE 802.11: Client associated
07:29:55, 03 Nov.
wlan1: STA 38:aa:3c:59:92:d8 IEEE 802.11: Client disassociated
07:29:54, 03 Nov.
BLOCKED 3 more packets (because of Packet invalid in connection)
07:29:54, 03 Nov.
OUT: BLOCK [9] Packet invalid in connection (UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on wlan0)
07:29:50, 03 Nov.
wlan1: STA 38:aa:3c:59:92:d8 IEEE 802.11: Client associated
07:29:46, 03 Nov.
wlan0: STA 38:aa:3c:59:92:d8 IEEE 802.11: Client disassociated
07:29:39, 03 Nov.
( 89.520000) CWMP: session closed due to error: No response
07:29:39, 03 Nov.
( 89.510000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
07:29:39, 03 Nov.
07:29:38, 03 Nov.
( 88.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
07:29:38, 03 Nov.
( 88.230000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
07:29:33, 03 Nov.
07:29:30, 03 Nov.
( 80.290000) Starting CHAP authentication with peer
07:29:30, 03 Nov.
( 80.290000) PPP LCP Receive Configuration ACK
07:29:30, 03 Nov.
( 80.200000) PPP LCP Send Configuration ACK
07:29:30, 03 Nov.
( 80.200000) PPP LCP Receive Configuration Request
07:29:29, 03 Nov.
( 79.630000) PPP LCP Send Configuration Request
07:29:26, 03 Nov.
( 76.140000) ETHoA is up -​ VPI: 0, VCI:35
07:29:26, 03 Nov.
( 76.140000) DSL is up
07:29:24, 03 Nov.
wlan0: STA 38:aa:3c:59:92:d8 IEEE 802.11: Client associated
07:29:24, 03 Nov.
( 75.080000) DSL noise margin: 15.00 dB upstream, 12.10 dB downstream
07:29:24, 03 Nov.
( 75.010000) DSL line rate: 448 Kbps upstream, 2112 Kbps downstream
07:29:14, 03 Nov.
07:29:06, 03 Nov.
( 56.930000) CWMP: session closed due to error: No response
07:29:01, 03 Nov.
wlan0: STA bc:30:7d:e6:2b:ff IEEE 802.11: Client associated
07:29:01, 03 Nov.
wlan0: STA bc:30:7d:e6:2b:ff IEEE 802.11: Client disassociated
07:29:01, 03 Nov.
07:28:54, 03 Nov.
BLOCKED 1 more packets (because of Packet invalid in connection)
07:28:54, 03 Nov.
OUT: BLOCK [9] Packet invalid in connection (UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on wlan1)
07:28:54, 03 Nov.
( 44.400000) WiFi auto selected channel 40
07:28:54, 03 Nov.
( 44.400000) 36-​128::40-​128::44-​128::48-​128::52-​128::56-​128::60-​128::64-​128::100-​128::104-​128::108-​128::112-​128::116-​128::120-​128::124-​128::128-​128::132-​128::136-​128::140-​128
07:28:54, 03 Nov.
( 44.390000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
07:28:52, 03 Nov.
( 43.030000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
07:28:52, 03 Nov.
( 43.020000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
07:28:52, 03 Nov.
( 42.420000) CWMP: Initializing transaction for event code 1 BOOT
07:28:49, 03 Nov.
( 39.780000) Wire Lan Port 4 up
07:28:48, 03 Nov.
( 38.950000) WAN Auto-​sensing running.
07:28:47, 03 Nov.
( 37.960000) System up, firmware version: 4.7.5.1.83.8.130.1.26.1.1 (Type A)
07:28:36, 03 Nov.
( 26.330000) WPA2 mode selected
07:28:36, 03 Nov.
( 26.330000) WPS enabled
07:28:34, 03 Nov.
( 24.850000) WPA/WPA2 mode selected
07:28:34, 03 Nov.
( 24.850000) WPS enabled
07:28:31, 03 Nov.
( 21.810000) System start
06:48:40, 03 Nov.
( 1209.410000) OpenWiFi IPSec connection is down
06:36:03, 03 Nov.
( 452.900000) Admin login successful by 192.168.1.66 on HTTP
06:36:01, 03 Nov.
( 450.680000) New GUI session from IP 192.168.1.66
06:30:59, 03 Nov.
( 148.940000) OpenWiFi IPSec connection is up
06:25:55, 03 Nov.
(76864.920000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>49266, internal ports: 49266, internal client: 192.168.1.66
06:18:58, 03 Nov.
(76447.340000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>49266, internal ports: 49266, internal client: 192.168.1.66
06:18:54, 03 Nov.
(76443.910000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>65124, internal ports: 65124, internal client: 192.168.1.66
06:13:04, 03 Nov.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19-​>81.158.121.98 on ppp0)
06:08:21, 03 Nov.
06:07:32, 03 Nov.
06:07:32, 03 Nov.
05:50:00, 03 Nov.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44-​>81.158.121.98 on ppp0)
05:49:37, 03 Nov.
IN: BLOCK [16] Remote administration (UDP [185.94.111.1]:51419-​>[81.158.121.98]:161 on ppp0)
05:48:14, 03 Nov.
IN: BLOCK [16] Remote administration (TCP [180.210.201.106]:7838-​>[81.158.121.98]:22 on ppp0)
05:47:25, 03 Nov.
05:37:36, 03 Nov.
05:37:35, 03 Nov.
05:37:35, 03 Nov.
05:37:32, 03 Nov.
05:37:32, 03 Nov.
05:17:34, 03 Nov.
05:17:34, 03 Nov.
05:17:33, 03 Nov.
05:17:32, 03 Nov.
05:17:32, 03 Nov.
20 REPLIES 20
Message 2 of 21
Re: Daily Dropouts
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
dephead2004
Message 3 of 21
Re: Daily Dropouts
Hi John.
Here is the line you asked for:
10:06:00, 02 Nov.( 89.260000) DSL is up
10:05:59, 02 Nov.( 88.240000) DSL noise margin: 14.00 dB upstream, 12.10 dB downstream
10:05:58, 02 Nov.( 88.170000) DSL line rate: 448 Kbps upstream, 2368 Kbps downstream
dephead2004
Message 4 of 21
Re: Daily Dropouts
BT openreach tester gives Download 1.7MBs and Upload 0.32Mbs
Quiet line test is clear
MAny thnaks again
Message 5 of 21
Re: Daily Dropouts
so according to your stats the last reset was at 10.05 yesterday so nothing this morning
dephead2004
Message 6 of 21
Re: Daily Dropouts
Hub reset this morningat 0625 whilst I was using the PC. Actually it reset itself most unusually. Took 5 minutes
Message 7 of 21
Re: Daily Dropouts
then I would expect the 2 lines you posted from the WAN stats to show that and not the reset on the 2nd
dephead2004
Message 8 of 21
Re: Daily Dropouts
OK so what does the line stats tell you?
dephead2004
Message 9 of 21
Re: Daily Dropouts
Do you need more info?
Message 10 of 21
Re: Daily Dropouts
I think the confusion is the 2 lines of stats you posted in message 3 as last set.
I think that should have been
07:29:24, 03 Nov.
07:29:24, 03 Nov.
