warrenshaw22
Message 41 of 107
Re: Dlm optional?
Just for an update, still no change, snr has stayed at 6 no problems at all, with very little errors but still will not sync any higher than 2279
Message 42 of 107
Re: Dlm optional?
@Techwizz the  connection is not banded just lower than max available  need to left to settle and hopefully DLM will move connection nearer attainable
warrenshaw22
Message 43 of 107
Re: Dlm optional?
Just had a missed call from guys saying you had worked my profile, now seeing a sync rate of 2891 😁
Message 44 of 107
Re: Dlm optional?
getting better just need to make sure connection remains stable
Moderator
Moderator
Message 45 of 107
Re: Dlm optional?
@warrenshaw22 It was me who called, good stuff I'm glad you're seeing an improvement. I'll run a few tests tomorrow again tomorrow to make sure it's stable. Smiley Happy
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Techwizz
Message 46 of 107
Re: Dlm optional?
@imjolly, how wasn't it? The line wouldn't sync any higher than a certain rate. That means it was banded.
Message 47 of 107
Re: Dlm optional?
@Techwizz At first I thought is was a banded profile but the more information posted it did not look like banded profile for adsl2  with about normal noise margin and a speed just about attainable
warrenshaw22
Message 48 of 107
Re: Dlm optional?
Much obliged NeilO, good improvement and been very stable, actually syncing higher than the attainable 😁 very much appreciated
warrenshaw22
Message 49 of 107
Re: Dlm optional?
Just an update for NeilO, all back to normal today. Interleaving now off, back on fast path with 3381 sync speed at 6 snrm. Thanks very much and Merry Christmas 😁
Moderator
Moderator
Message 50 of 107
Re: Dlm optional?
@warrenshaw22 Brilliant, I'm glad thats sorted Smiley Very Happy
Kudos”Kudos”
