warrenshaw22
Message 51 of 107
Re: Dlm optional?
Hi gents,
Just for an update, unfortunately now back to the same problem, stuck on 2279 sync rate with 3300 attainable.
The problem is, it is rock solid at 6snrm and get a really good connection, but then because of this the dlm drops the snrm to 3, causing the drop outs and getting me stuck on a low sync rate again. If it would just stay at 6 I don't think I would be having any problems.
Probably the move to adal2 has not helped as it seemed more stable on dmt
warrenshaw22
Message 52 of 107
Re: Dlm optional?
Is it possible at all to be moved back to 20cn as the line seems to be more stable? The dlm seems very aggressive on adsl2
Message 53 of 107
Re: Dlm optional?
Maybe stay on adsl2 and see if mods can fix noise margin to 6db which will help stabilise your line and as long as stable DLM will not drop to 3db.  Will need to give up a bit of speed to get the 6db
warrenshaw22
Message 54 of 107
Re: Dlm optional?
Thanks for the reply, the snr did come back to 6 a few days ago.
warrenshaw22
Message 55 of 107
Re: Dlm optional?
5da ys in now and still stuck on the 2272 profile (2mb) with 3300 attainable.
My connection was always brilliant around a 3300 sync speed, then the dlm would sync higher after a while nearer 4000 and this is what causes the drops and me ending up stuck on 2272.
Just a query, is it possible the mods can set a banded profile of 3328 on my line? This would possibly fix my problem as it couldn't sync me any higher? I'd be quite happy with that speed if is stayed stable and reliable , rather than suncing higher and getting stuck with lower speeds in the end.
Message 56 of 107
Re: Dlm optional?
can't set speed hence why I suggested setting noise margin but cannot fix it as with disconnections the DLM will override and take action
warrenshaw22
Message 57 of 107
Re: Dlm optional?
Ah, OK, shame speed can't be set, would of solved all problems, thanks for your response.
Is there pretty much nothing can be done bar reseting the line again?
warrenshaw22
Message 58 of 107
Dlm reset ease
As per previous posts, the dlm has now decided again to get me stuck on 2mb profile due to drops at night.
Always usually have a 3.5 sync, now my max attainable is 2.7.
Router stats below connected over 6 days now and not bidgi g sync:
DSL Down Up
Current Rate: 2272 kbs 1046 kbs
Max Rate: 2713 kbs 1049 kbs
Current Connection:
Current Noise Margin: 6.1 dB 5.8 dB
Current Attenuation: 58.7 dB 34.1 dB
Current Output Power: 17.7 dBm 11.8 dBm
Broadband Link – Detailed DSL Statistics
Collected for 6D 1:19:40
ATM Since Reset Current 24-Hour Interval Current 15-Minute Interval Time Since
Last Event
Cell Header Errors: 0 0 0 0:00:00
Loss of Cell Delineation: 0 0 0 0:00:00
DSL
Link Retrains: 0 0 0 0:00:00
DSL Training Errors: 1 1 0 6D 1:18:40
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 0 0 0 0:00:00
Loss of Signal Failures: 0 0 0 0:00:00
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 0 0 0 0:00:00
Cumulative Seconds w/Errors: 0 0 0 0:00:00
Cumulative Sec. w/Severe Errors: 0 0 0 0:00:00
Corrected Blocks: 239 239 2 0:00:42
Uncorrectable Blocks: 0 0 0 0:00:00
DSL Unavailable Seconds: 58 58 0 6D 1:18:21
Message 59 of 107
Re: Dlm reset ease
you need to keep you posts in one place as the past history is needed to show ongoing problem
there is obviously a problem with your conenction and if not dropping then line errors resulting in DLM taking action to reduce speed and increase noise margin
should really remove the 'solved' as this is still ongoing
warrenshaw22
Message 60 of 107
Re: Dlm reset ease
Yes, that makes sense, thanks a lot.
How do I remove it as 'solved'?
