warrenshaw22
Message 21 of 86
Re: Dlm optional?
I have an open reach splitter faceplate, I did try that last time I had this problem and made no difference, although, am quite happy to do it again, although I I would have to turn modem off after a 5 day sync. Do you think this is a problem which will fix itself after no movement in 5 days?
Message 22 of 86
Re: Dlm optional?
at present your max estimated speed is only 2268kbps not the 3.5/4mb estimated so suggests poor/bad connection. I would normally expect an estimated of 3.5/4mb and  connection of 2074kbps and high 12db noise margin showing scope for speed improvement  at present it show max only 2268kbps
as you have already posted stats showing 5 days stable then conencting to test socket with a filter and reposting stats will show is that helps either attainable/actual speed and noise margin  if no improvement and no line line then can see if mods will reset noise margin back to 6db which will improve speed
warrenshaw22
Message 23 of 86
Re: Dlm optional?
Should I post the stats straight away after test socket?
warrenshaw22
Message 24 of 86
Re: Dlm optional?
Status
xDSL
xDSL
Mode ADSL_2plus
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 12.1 6.1
Attenuation (dB) 55.0 34.3
Output Power (dBm) 16.5 12.1
Attainable Rate (Kbps) 2292 883
Rate (Kbps) 1979 887
MSGc (# of bytes in overhead channel message) 51 14
B (# of bytes in Mux Data Frame) 70 46
M (# of Mux Data Frames in FEC Data Frame) 2 1
T (Mux Data Frames over sync bytes) 1 2
R (# of check bytes in FEC Data Frame) 16 10
S (ratio of FEC over PMD Data Frame length) 2.2491 1.6764
L (# of bits in PMD Data Frame) 562 272
D (interleaver depth) 1 16
Delay (msec) 8 7
INP (DMT symbol) 29.00 2.00
Super Frames 0 0
Super Frame Errors 0 0
RS Words 88627 116891
RS Correctable Errors 0 123
RS Uncorrectable Errors 0 0
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 234100 95554
Data Cells 2852 1124
Bit Errors 0 0
Total ES 0 0
Total SES 0 0
Total UAS 52 52
Message 25 of 86
Re: Dlm optional?
stats still about the same  see if mods will reset noise margin back to normal 6db as you have 5 days stable conenction and take it from there   mods will post here
warrenshaw22
Message 26 of 86
Re: Dlm optional?
Much obliged for your input
Moderator
Moderator
Message 27 of 86
Re: Dlm optional?
Hey @warrenshaw22,
We'll run our tests and if there are no underlying issues we'll look at changing the DLM for you again Smiley Happy
I'll need your details again though please. I've made our contact link available to you in my profile.
DanielS
Community ModeratorDannyS
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
warrenshaw22
Message 28 of 86
Re: Dlm optional?
Thanks very much DanielS, details have been sent
warrenshaw22
Message 29 of 86
Re: Dlm optional?
Not sure if it was you guys, but my snr has dropped back down to 6 this morning 😁
warrenshaw22
Message 30 of 86
Re: Dlm optional?
Has crept back up a bit again, but seems to be trying to sort itself, there are three open reach vans down the road working up on the line, must have had something to do with it
