warrenshaw22
Message 71 of 107
Re: Dlm reset ease
Just for update, have been connected now another three solid days, 5 days straight before that, and the snr seems to be recovered at 6 for the last three days, but the sync speed still stuck at 2172? Not sure what to do now, should I reset the modem to see if it now syncs at the attainable rate, or leave it alone and see if it will resync itself? Thanks
warrenshaw22
Message 72 of 107
Re: Dlm reset ease
Well powered the modem down for 30 minutes, turned back on, same stats.
2272 connection rate with 3200 attainable at 6snr. There has been in total nearly 9 days connection with good stable line and ip still stuck at 2mb. Can someone please, please reset my line
Message 73 of 107
Re: Dlm reset ease
if as you say you now have a stabl;e conenction with 9days and still in banded profile then I have asked mod to help again
warrenshaw22
Message 74 of 107
Re: Dlm reset ease
Thanks a lot, this adsl is so frustrating, I have replaced faceplate etc all in house and all seems fine here with good attainable rate, just dlm won't catch up.
Soon as this contracts up think I'm heading for a 4g box!
Moderator
Moderator
Message 75 of 107
Re: Dlm reset ease
Hi @warrenshaw22
Thanks for posting back.
I'm pleased to see that your connection is looking much more stable now.  Sorry that your speed is still banded.  We will be able to help get your speed back up closer to where it should be.
I have sent you instructions via private message on how you can contact us and we'll take it from there.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 76 of 107
Re: Dlm reset ease
Hi @warrenshaw22 I have arranged for a reset of the connection. This will complete within 24hrs please keep and eye on your connection and keep the thread updated to let me know how your connection is performing
cheers
John
Community ModeratorJohnC
Kudos”
warrenshaw22
Message 77 of 107
Re: Dlm reset ease
Thanks very much for that, will keep an eye for the reset and keep you updated, thanks very much to everyone for your help 😊👍
warrenshaw22
Message 78 of 107
Re: Dlm reset ease
Hi John 2, just to keep you updated, the line has not been reset as yet.
warrenshaw22
Message 79 of 107
Re: Dlm reset ease
Hi, still no reset has occurred?
Moderator
Moderator
Message 80 of 107
Re: Dlm reset ease
Hi @warrenshaw22 I called earlier sorry I could not reach you and the reset doesn't appear to have taken place. I have tried to check your connection but I am not picking up an active broadband session. Can you confirm your connection is up and working ok and I will raise another reset order if necessary.
John
Kudos”
