Bc1973
Message 1 of 7
Do I have a faulty SSFP infinity socket?
We've just moved in to a new property and have finally located the SSFP socket for our Infinity 2 setup. It has the standard ADSL socket at the top and phone socket beneath. But it doesn't work. The HH5 light is yellow and the red 'b' flashes and we have no connection.
However, right next to the SSFP socket is a more normal looking phone point with the Openreach logo on it. If we plug an ADSL filter in here and the HH5 in to that, it works. BUT... we can't plug a phone in anywhere else but this filter.
Why would we have this setup and not a normal SSFP active? As I said before, we've just moved in so I have no history on this.
6 REPLIES 6
Bc1973
Message 2 of 7
Re: Do I have a faulty SSFP infinity socket?
I should say it's an SSFP type 5 not type 3
Distinguished Guru
Message 3 of 7
Maybe the previous customer had 2 lines and bt have provided your line on the non ssfp socket.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Bc1973
Message 4 of 7
Ok. So how would I change that? I've only found one other working phone point in the house (despite their being 4 in total) and I'd rather not have ADSL filters everywhere.
Message 5 of 7
if working socket is an NTE5 then just undo SSFP take out the section shown by yellow arrow, put into NTE5 and replace bottom section shown by red arrow
Bc1973
Message 6 of 7
Sorry, don't follow. Do you mean just swap the two fascias over? Move the SSFP fascia on to the other one?
Message 7 of 7
yes  the insert with yellow arrow has a slot in bottom so slips over any existing extension wiring conencted to existing faceplate shown by red arrow  then put back together
