minusdot
Recognised Expert
Message 1 of 11
Do I have to reset my HH2 to get rid of BT Fon?!
Over a week ago I opted out of BT Fon. My hub's been on constantly since, yet my HH's status page still shows BT Fon as active and I can see BTOpenZone and BTFon in my available networks list. 😞
I've restarted the hub, but it's still there. Do I have to do a reset to get rid of it? And if so, I hope a Settings Only reset will suffice, I don't want to mess up my Hub Phones.
10 REPLIES 10
gavaskarss
Message 2 of 11
Re: Do I have to reset my HH2 to get rid of BT Fon?!
Hi Minusdot,
To get rid of the BT FON Network,please login to www.bt.com/btfon and then select check status and opt out of BT Fon network.You will need your BT username and Password
After opting out of BT Fon it will suggest you not to turn off the router for 48 hours
Message 3 of 11
normally a factory reset clears it
minusdot
Recognised Expert
Message 4 of 11
A settings only reset did the trick. I had to configure the hub to get BBTalk to work again, but at least I didn't need to repair the phones or lose my shared contacts.
Odd that it didn't just unsubscribe itself though. I guess BT Fon really don't like to lose customers! 😉
hamish72
Recognised Expert
Message 5 of 11
It don't like to get new ones either I subscribed but the hub refuses to acknowledge the fact
Its shown as active in the sign up site and works just the hub don't wish to know
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
minusdot
Recognised Expert
Message 6 of 11
BT Fon is now active again on my HH2! 😞 I've checked my status and I'm still correctly shown as opted out.
Ideas anyone? Would contacting THD help?
Community Manager
Community Manager
Message 7 of 11
Hi Minusdot,
Its odd that your hub has started transmitting the Fon and Openzone SSID after you have opted out of Fon.  I can look into this for you.
Please drop me an email to the email address in my profile. (click on my name and you will find the address under the "about me" section). Include your BT account details and the link to this thread.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
minusdot
Recognised Expert
Message 8 of 11
I've unmarked this thread as solved.
I've now followed DS's advice and emailed btfonenquiry@bt.com. Fingers crossed they can disable this unwanted service.
Distinguished Guru
Message 9 of 11
Hi minusdot
In reply to your subject heading, no you don't have to reset your hub (and imho, you shouldn't have to!)
I'll keep an eye out for the "Yipee, no more Fon!" post on this thread:smileywink:
-+-No longer a forum member-+-
minusdot
Recognised Expert
Message 10 of 11
Yipee, no more Fon! 🙂
