Leehebrides
Message 21 of 55
Re: EO Lines in entire township
When I spoke to the huawei engineer who was connecting the lines last week he said they were all done, looks like I maybe to close to the box
Message 22 of 55
you cannot be to close to the box
Message 23 of 55
The physical work may be done but maybe the records haven't all been updated yet.
Message 24 of 55
Records can take a few weeks to all update and align.
If you're no further forward in a couple of weeks, come back and we'll see if a moderator can step in to ask Openreach to check their records.
Leehebrides
Message 25 of 55
Thanks all, I checked all , checked the other houses in the township , even the property connected to mine and they all say available , mine is not. Could it be my line, it will be about 35 years old and star wired
Message 26 of 55
Would make no difference.
If yours is genuinely the only one not showing up as now being connected to the cabinet, then perhaps it's time for a mod to chime in to see if they can ask Openreach to check their records.
Leehebrides
Message 27 of 55
My checker reply
Leehebrides
Message 28 of 55
IMG_4495.PNGProperty next door
Message 29 of 55
Yip looks like a DB error.
Leehebrides
Message 30 of 55
How do I get that corrected please, as far as I can tell openreach will not talk to individual customers or will have have to ask a OR engineer when they come to the box, i do appreciate all the reply guys I just getting frustraited. so thank you again
