norsenoddy
Message 1 of 12
Electric fencing
Hi I have major problems keeping a usable connection every year between May - November . I know the main ( I think ) cause " Electric Fencing " which runs directly  parallel with underground line for about 200 mtrs  , is there any solution for this ?  cheers
11 REPLIES 11
Message 2 of 12
Re: Electric fencing
Electric fencing if properly insulated, should not cause problems. Its only when sparking occurs due to poor insulation or proximity to nearby objects,
If you can take a portable medium wave radio, and walk along the route of the fencing, you should be able to her a load click every couple of seconds. This will be loudest where the sparking is occurring, and you may even hear the sparking audibly, when you are very close.
If you can identify where it is sparking, then you may be able to see the cause, and ask the farmer if they could help.
norsenoddy
Message 3 of 12
Thanks for the reply , I've done that test many times and get a constant clicking which matches the clicking on the telephone but appears the same all along the fence Smiley Sad
Message 4 of 12
Electric fences 'pulse' a high voltage from a 12v battery, it will be the pulsing energiser that is affecting the broadband. Other than persuading the farmer not to use the fencing, I'm afraid there is very little you can do.
Found this Googling
TV AND TELEPHONE INTERFERENCE
HOTLINE Energisers do not cause interference. This is normally caused by bad joints, leaking insulation or vegetation touching the fence line. If you are experiencing interference please follow the checklist below:
  • The Energiser Earth system must be sufficient.
  • The Energiser Earth System must be 10m away from the mains supply, safety Earth and buried water pipes.
  • The energiser MUST NOT be connected to the mains supply safety earth or to the water supply pipes.
  • The mains power supply plugs and sockets for the radio and the energiser must be in good working order. No Loose Connections.
  • The energiser earth cable must not touch buildings, which can act as a broadcast aerial. Use double insulated (HTG) cable or run the wire to earth using HOTLINE insulators.
  • The energiser's ground system should be at least 10m away from radios and buried telephone wires.
  • Avoid running the electric fence line parallel to power or telephone lines.
  • Use only top quality HOTLINE insulators. Sparking inside cracked or poor quality insulators causes interference.
  • Vegetation touching the fence line close to the radio can also cause sparking and therefore interference.
  • To locate sparking caused by leakage, faulty joins, broken wires or faulty insulators, walk the fence line with a transistor radio tuned off station on the AM band on high volume. The clicking will get louder as the fault is approached.
norsenoddy
Message 5 of 12
it's battery powered but the grounding is very close to underground lines ( I also think it's pretty poor one rusty rod about 1 and a half mtrs long ) and runs parallel , I'll have get out for a longer walk with the radio sometime , cheers
Distinguished Guru
Message 6 of 12
As mentioned, tune the AM radio to 612KHz and walk the route. Openreach REIN trained engineers have a tester to locate the source but all it is is an AM radio.
They can locate where the problem lies however they have no powers to instruct the person who's equipment is causing the problem to get it repaired or turn it off
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
norsenoddy
Message 7 of 12
It's going to be a good long walk testing this fence covers about six fields 😞
norsenoddy
Message 8 of 12
Why is this marked as a solved ? the problem isn't solved I still have useless internet
Distinguished Guru
Message 9 of 12
I guess it's because that's about all the help the forum can give you.
Moderator
Moderator
Message 10 of 12
Hi @norsenoddy  and welcome back.
Thanks for posting. I'm sorry you're having problems with the electric fence causing your broadband to drop out. The advice offered by the other members is correct in this case. Your best bet might be to speak with the farmer to try and resolve this. Sorry we can't be of any more help this time.
Cheers
David
