Message 11 of 16
Re: Extending Broadband/Phone line
@carday56 wrote:
And there lies my problem my particular version of that master box does not have the data extension terminals on the front.
They are hidden behind the front plate.
If not, then you will have to extend the RJ11 cable, you can get RJ11 data extension leads with different lengths.
Recognised Expert
Message 12 of 16
Hi @carday56 can you provide a photo of the NTE5 with the bottom face plate disconnected?
Message 13 of 16
I will when i get home from work
Moderator
Moderator
Message 14 of 16
Hi @carday56 ,
Did you manage to get this sorted? We're keen to know if you did as it might benefit other forum users. Can you post back and give us an update?
Cheers
David
Message 15 of 16
Yes I did, because there was only 2 incoming wires to the property it be became apparent that that an extension was all that was needed, all wired up all working okay
Moderator
Moderator
Message 16 of 16
That's fantastic @carday56 . Thanks for letting us know you're all sorted.
Post back if you have any other questions.
All the best
David
