Message 1 of 7
Extension cable for broadband
  hi.    Fitting an extension cable from the mastersocket to another room.  I’ve tagged the red wire to connector 4 and the white to connector 5.   The previous connector used these numbers but I’m concerned this must be different as I can’t get a dial tone.   Thanks in advance
6 REPLIES 6
Message 2 of 7
Re: Extension cable for broadband
Are you a BT broadband customer
what do you intend to use the old extension for?
Message 3 of 7
From main socket to front room to power Bt hub
Message 4 of 7
is the main socket a filtered master socket?
Message 5 of 7
Yeah. 2 outlets beside each other. Mastersocket 5c
Message 6 of 7
I’ve a red and white wire to match with connector 2, 3, 4 or 5
any advice would be great
Message 7 of 7
Sorted it
2 white and 5 red
working fine now but just want to check this is safe.    There’s a built in filter at master socket also
