Moderator
Moderator
Message 31 of 60
Re: Extremely slow adsl broadband been ongoing for months please help!
Hi @Kev2 and thanks for posting.
We'll need to take a closer look at this for you so please send over the details and we'll take it from there. You'll get the contact the moderators link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Kev2
Message 32 of 60
Hi @DavidM
Thanks for your reply. May I ask how I contact you and what details you will require?
Regards,
Kevin
Message 33 of 60
if you open the link in DavidM;s profile it will take you to a contact form to complete the mods then personally own your problem until fully resolved
Message 34 of 60
hope that helps you
Kev2
Message 35 of 60
Hi @DavidM
Thanks, details sent. an updated screen shot from this morning, just for the record...
Kev2
Message 36 of 60
Still waiting for the mods to get back. The hub restarted itself for the millionth time yet again at 7.00 this morning and now even slower, please see update below:
Message 37 of 60
It will take 3/5 working days for the mods to contact you personally once they receive the contact form as they deal with each mail strictly in turn
Kev2
Message 38 of 60
This morning, restarted itself again and now gone right back down to what it was in the first place 287 Kbps, even the upstream is slower than what it was, now only 406 Kbps. I know like you say the mods are busy but me and my family heavily rely on a stable and fast connection so this is really not good for us...
Message 39 of 60
There is nothing you can do other than wait for the mods it is looking like you may need an Openreach engineer visit as it is looking more like a possible line fault as I have posted the mods deal with every mail strictly in turn also weekends do not count in the waiting time
Kev2
Message 40 of 60
It can't be a line fault as when I previously posted a screen shot on the 10th of November when the speed first came back it clearly shows that the connection was over 13 Mbps down and over 1 Mbps up, it stayed like that for over ten hours straight, if there was a line fault those speeds could never have been achieved.
