Message 1 of 13
FTTP only?
Hi,
I am about to move to a rental property that has standard copper phone/ broadband line. I have been told by bt that the line has to be upgraded to full fibre as they have upgraded the local cabinet so that it now only uses full fibre. Ideally I do not want full fibre due to the additional equipment that needs to be installed within the house and also as the house is grade 2 listed I have to be careful where the outside connection is positioned. Can I insist on keeping the copper line or is this just not possible. Amy advice would be appreciated.
12 REPLIES 12
Message 2 of 13
Re: FTTP only?
FTTP does not come from the street cab so any upgrading is nothing to do with FTTP
enter your phone number or address and post results
Message 3 of 13
Re: FTTP only?
I do not have a phone number yet unfortunately. Could it be the exchange that has been upgraded. I gave the address the the moving home team and was told that due to an upgrade to the infrastructure that I needed an fibre line, external box and obviously an internal modem. The property has had a phone line and broadband a couple of years ago
Message 4 of 13
Re: FTTP only?
use your new address in the checker and post result  remember delete address before posting
Message 5 of 13
Re: FTTP only?
How do I post the results? My screen shots are to large to upload. Here is some information from the property search
It states ADSL Multicast as available
WLR withdrawn as No
SOADSL Restriction as yes
It says the premises/line is associated with exchange which is NOT part of current fibre priority program.
FTTP NETWORKservice information. Single dwelling unit. Residential UG partial direct in ground.
FTYP is available and a new ONT may be ordered.
Message 6 of 13
Re: FTTP only?
use the camera icon to post
Message 7 of 13
Re: FTTP only?
Message 8 of 13
Re: FTTP only?
Message 9 of 13
Re: FTTP only?
As a phone line also has to have an entrance to the house, I would imagine they can run the fibre into the hole for that if the copper is no longer connected so the external would look pretty much the same apart from a slightly larger (ok more than slightly, but not excessive) box on the outside.
Inside the ONT they are fitting is about 3' square so very small, and you would need a router nearby even with VDSL.
I imagine you would need the owners permission though, but as FTTP would be a selling point in the future, I would imagine they would be open to it ?
Message 10 of 13
Re: FTTP only?
think you got size wrong 3' (ft) square is not small
