ljm
Expert
Message 1 of 3
Factory Reset
Hello,
Does a Factory Reset cancel out my present Wireless Password and Admin Password in Hub 6 and send them back to the Default passwords on the back of the hub?  I'm just wondering whether, in order to connect following the Factory Reset do i need to use my default passwords or my present passwords??
I just always get confused with this basic stuff of Factory Reset.
2 REPLIES 2
Message 2 of 3
Re: Factory Reset
Factory reset does exactly that, restores the hub to how it left the factory. Any password changes you have made will be lost and will revert to those printed on the hub/card.
ljm
Expert
Message 3 of 3
Re: Factory Reset
Thanks for making that clear Licquorice!
