bjosh
Message 1 of 21
Fast Latency request
Hello I am wanting my latency changing from interleaving to fast please as i do a lot of gaming
thanks
1. Product Name: HomeHub5 2. Serial number: +076284+1512010071 3. Firmware version: v0.07.07.03230-BT (Type B) Last updated 11/5/2018 4. Board version: 01 5. ADSL uptime: 0 days, 04:37:50 6. Bandwidth: 448 / 1888 7. Data sent/received: 34.1 MB / 277.0 MB 8. Broadband username: bthomehub@btbroadband.com 9. BT Wi-fi: No 10. 2.4GHz wireless network/SSID: BTHub5-6ZFR 11. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 300 Mb/s)) 12. 2.4GHz wireless security: WPA2 Only (Recommended) 13. 2.4GHz wireless channel: Automatic (Smart Wireless) 14. 5GHz wireless network/SSID: BTHub5-6ZFR5GHz 15. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 16. 5GHz wireless security: WPA2 Only (Recommended) 17. 5GHz wireless channel: Automatic (Smart Wireless) 18. Firewall: Default 19. MAC Address: 5c:dc:96:00:47:40 20. VPI/VCI: 0/38 21. Modulation: G.992.1(DMT) 22. Latency type: Interleaved 23. Software variant: - 24. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
20 REPLIES 20
Moderator
Moderator
Message 2 of 21
Re: Fast Latency request
Hi @bjosh Welcome to the forum and thanks for posting.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
bjosh
Message 3 of 21
Hi thanks but I can’t see the contact mods option?
Message 4 of 21
your are on adslmax  can you enter your phone number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
your conenction time is very short was that a manual reset or are you having problems with conenction dropping hence you are on interleaved and not fast
bjosh
Message 5 of 21
hi @imjolly it was a manual restart
Message 6 of 21
You would benefit from upgrading to adsl2 and could ask mods to help that way you could improve your speed and get latency changed to fast
based on the dslchecker results  your current connection speed looks very low - have you tried connecting to test socket with a filter to see if that improves your speed
bjosh
Message 7 of 21
@imjollyhow do I contact them to request this change? Thank you
Message 8 of 21
Did you find the mod 'contact us' following the mod link
Moderator
Moderator
Message 9 of 21
@bjosh If you fill in the contact the mods link that @JohnC2 made visible to you earlier today we'll be able to organise this for you.
Community ModeratorNeilO
Kudos”
bjosh
Message 10 of 21
Thanks @imjolly I’ve sent it across.. by the way, on the dsl checker it says wbc fttc is available.. what is this exactly and is it better to go for that than my current adsl?
