bbbill999
Message 1 of 6
I have had an intermittent fault in broadband for 6 months
Finally died two weeks ago
Reported it
Reply was all fixed
Reported again
The report is for a phone fault and it’s a broadband fault running slow or not at all Slow meaning 1/4 instead of 5 . Not at all means no connection.
How do I make sure they are looking at broadband Have phoned twice to change it & failed! Tried to change contact numbers and failed ... not going well, but hoping an engineer arrives in the morning ready to do broadband not phones!
5 REPLIES 5
bbbill999
Message 2 of 6
Re: Slow Broadband speed and drop out
I have just posted the same issue & im worried
Message 3 of 6
@bbbill999
I have merged your 2 posts as they are about same subject
Message 4 of 6
is your phone currently working?  if so try quiet line test  dial 17070 option 2  should be silent apart from announcement and best with corded phone
can you post stats from your hub?
enter your phone number and post results  delete number but leave exchange and cab number  https://www.btwholesale.com/includes/adsl/main.html
bbbill999
Message 5 of 6
Hello mr/ May Jolly
The engineer arrived this morning and fixed it all. Fault was outside &!i understand in two separate places.
Thanks for your attention
Bill
Message 6 of 6
great thanks for update
