schford
Message 1 of 28
Faulty Router changed - now need target SNR, interleaving and DSLAM profile all reset..
Router was up and down like a yo yo over Christmas which resulted in my Target SNR going up, Interleaving being turned on and no doubt my DSLAM profile being way slowed down .....
New Billion 7800 dxl router installed and all hunky dory and up again - but now instead of synching at 16ish Meg it is 8ish with max attainable speed of less than 10!!!.....and thats with my attentuation dropping to 29 with this new router rather than the old 32! So I would epxect faster...
I need everythign reset back to normal Target SNR of 3, interleaving off and DSLAM reset - but I notice the old contact a forum mod to have it done at https://bt.custhelp.com/app/contact_email/c/4951 is no longer valid.....
I really dont want to have to sit on the phone and step through a million questions with the Indian tech support only for it not to be done and me twiddle my fingers for 10 plus days until it (maybe?) happens automatically.
Does anyone know a quicker way?  I can override the target SNR on my router but dont really want to do that as it will end up too low when it is finally reset! plus nonw of the other changes will happen.
Thanks very much in Advance (and even for looking at my post).
Stuart
27 REPLIES 27
schford
Message 2 of 28
Re: Faulty Router changed - now need target SNR changed back ...
Message 3 of 28
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more and then if needed the forum mods may post an invite of help
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
schford
Message 4 of 28
Im not sure what posting the stats will give that my explanation didnt?
However here they are....
As a result of a duff router over the christmas break, it looks like my DSLAM profile got capped to a max of 9980 (it used to be just under 20 meg), Target SNR up to 6db from 3db and interleaving turned on....
Router is straight into the master socket.....
ADSL stats
xDSL
ModeADSL_2plus
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)6.15.5
Attenuation (dB)29.015.0
Output Power (dBm)0.012.9
Attainable Rate (Kbps)99801220
Rate (Kbps)83171214
MSGc (# of bytes in overhead channel message)5910
B (# of bytes in Mux Data Frame)12956
M (# of Mux Data Frames in FEC Data Frame)14
T (Mux Data Frames over sync bytes)23
R (# of check bytes in FEC Data Frame)108
S (ratio of FEC over PMD Data Frame length)0.49825.9746
L (# of bits in PMD Data Frame)2248316
D (interleaver depth)644
Delay (msec)86
INP (DMT symbol)1.000.00
Super Frames195711176736
Super Frame Errors21
RS Words237709781979623
RS Correctable Errors8522822
RS Uncorrectable Errors00
HEC Errors21
OCD Errors00
LCD Errors00
Total Cells580825458457813
Data Cells836855218600
Bit Errors00
Total ES21
Total SES00
Total UAS131131
BT SPEED TEST
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 7.31 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 7.31 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 7.34 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 1.04 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 1.04Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Message 5 of 28
Due to all the disconnections you are in a banded profile you need to maintain a stable connection for 3/5 days and you will start to lift out of the banding automatically
schford
Message 6 of 28
My understanding is that wont reset interleaving etc though - or have things change din last couple of years - used to need a manual itnervention.
Message 7 of 28
correct it will not affect interleaving that will need manual intervention but again you will need to be able to show at least 3 days + before the mods would move you back to fastpath i would suggest getting the banding released first before any thing else
schford
Message 8 of 28
Thanks for info - guess I will twiddle my fingers for a few days before posting back 🙂
Stuart
schford
Message 9 of 28
Almost 4 days now and no change in speed and a rock solid connection (not a suprise being half the usual speed) - could I humbly repeat my plea to get my profile reset, target snr reset to 3 and interleaving turned off...
New router rock solid...
Stuart
WAN
Line Rate - Upstream (Kbps)1214
Line Rate - Downstream (Kbps)8317
Default Gateway / IPv4 Addresspppoa0 (DSL) / 109.150.56.206
Connection Time3 Day(s) 20:35:09
Primary DNS Server213.120.234.74
Secondary DNS Server
194.72.0.98
xDSL
ModeADSL_2plus
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
SNR Margin (dB)5.15.8
Attainable Rate (Kbps)95841216
Rate (Kbps)83171214
Delay (msec)86
Super Frames2060244618603870
Super Frame Errors84497
RS Words26766465363998631
RS Correctable Errors308094943129
RS Uncorrectable Errors4980
HEC Errors203987
OCD Errors00
LCD Errors00
Total Cells2245139152953381909
Data Cells13335377456369521
Bit Errors085827
Total ES70236
Total SES00
Total UAS1311
schford
Message 10 of 28
connection is all the more impressive being rock solid when my lane is like this - https://www.youtube.com/watch?v=piIm-bDIGsM and before the flooded bit the cables are all underground!
