Panmaster
Message 1 of 5
Faulty phone line
I've checked the internet connection at my grandmothers house again and it's still not fixed.
This problem has been ongoing for months now.
The obvious solution here would be to leave BT and move to a ISP that isn't completely and utterly useless but that is not an option as I have no say.
Phoning is a waste of time as the callcenter is staffed with poor english speakers with zero technical knowledge.
How do I get BT to send the SFI engineer that is needed to fix the line fault?
ADSL Line Status
Connection Information
Line state: Connected Connection time: 0 days, 00:16:40 Downstream: 280.6 Kbps Upstream: 1.055 Mbps
ADSL Settings
VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.5 Annex A Latency type: Interleaved Noise margin (Down/Up): 34.0 dB / 8.0 dB Line attenuation (Down/Up): 37.1 dB / 22.5 dB Output power (Down/Up): 8.4 dBm / 12.8 dBm FEC Events (Down/Up): 0 / 0 CRC Events (Down/Up): 0 / 303 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 0 / 13 Error Seconds (Local/Remote): 101 / 63256
"Ignorance is bliss"
4 REPLIES 4
Message 2 of 5
Re: Faulty phone line
from your previous thread you said that the noise disappeared when filter remove.  if that is the case and you get an engineer you could land your grandmother with a £99 callout bill
looking at the stats the line is in a banded profile hence the low speed and high noise margin.  connection time is only 16hrs is that due to drop in conenction or router being switch off when not in use?
have you tried quiet line test from test socket with new filter?  dial 17070 option 2  should hear nothing and best with corded phone    if cordless then dull hum normal
Message 3 of 5
also changing ISP's would not solve a line problem as all ISP's except Cable use the same Openreach infrastructure
a stable connection with no hub restarts is needed for 5 days is needed for you to start lifting out of the banding you need the hub to be powered up 24/7
Panmaster
Message 4 of 5
I'll recommend leaving BT for voice and adsl.
(1) the router never used to be turned on 24/7 and the connection was 8mbps down.
(2) now it's on 24/7 and can't stay stable at 280kbps. It loses sync often.
(3) The "quiet line" test is useless. You can't hear adsl frequencies. D'oh!
Message 5 of 5
The quiet line test is not listening for adsl frquencies but just plain line noise when making a phone call. If you have any oise on the phone line then that causes massive problems with your broadband causing drops in connection, high noise margin and low connection speed
As already said moving to another ISP will not solve the problem if you have line noise - up to you
