Message 1 of 12
Fibre Installation
Can anyone confirm fibre installation is fairly imminent near me, or am I looking at a longer timeframe?
BT when and where suggests it's in the "Build Phase" and availability within 5 months normally and has been like this since May/June 2017.Screenshot_2017-12-15-09-43-48-165_com.android.chrome.png
Tags (1)
11 REPLIES 11
Sage
Message 2 of 12
Re: Fibre Installation
As the date has not yet been confirmed it looks like a longer timeframe.
Message 3 of 12
Welcome to this user forum.
Only Openreach would know that.
Message 4 of 12
Thanks for the response. A little frustrating as the current speeds offered are just not sufficient for the household needs, hopefully soon.
Is there any way to find out further information via Openreach/BT or elsewhere.
Message 5 of 12
If you are on ADSL2+, you should be getting more than enough speed for normal household use. 7-10.5 Mbs.
Are you sure you are getting the correct speed?
As far as Openreach is concerned.
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre
Message 6 of 12
Normally I would be getting 2-3Mbps. It's incredibly rare to get it to peak 5+.
1GB roughly takes 45minutes to download.
Usually when I am gaming, and if someone tried to stream YT/Netflix simultaneously, gaming becomes impossible.
Also at times the connection can drop below 1Mbps, where even normal web browsing becomes impossible and need to resort to mobile broadband
I assume I am on ADSL2+, but how would one check if I am?
Message 7 of 12
post stats from your router please
Message 8 of 12
Currently at work, I'll post stats in evening. Thanks.
Message 9 of 12
You should be getting a better connection that you are getting.
Recognised Expert
Message 10 of 12
Could be imminent:
https://www.telecom-tariffs.co.uk/codelook.htm?xid=948508&cabinets=10411
Cabinet P27  FTTC being Built, live due by December 2017  Phase 18a     Huawei  WF17 6AN
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
