gtomlin
Newbie
Message 1 of 3
Forgotten Password for BT Home Hub
I must have changed my password a while a go from the default but now i am unable to log in as i have forgotten what my password was, is there any way you can reset the home hub's password back to default.
Cheers
Message 2 of 3
Re: Forgotten Password for BT Home Hub
You will have to reset the hub back to factory default settings.
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
Distinguished Guru
Message 3 of 3
gtomlin wrote:snip
Yes there is. Use this link, it'll tell you how - http://bt.custhelp.com/app/answers/detail/a_id/11386/kw/c/346,1887,4020
-+-No longer a forum member-+-
