keithdw
Message 1 of 5
Frequent Dropped Connections Since PowerCut
Hi, we had a power cut the other night, from which the broadband did not immediately come back up. So i called the support team, who were very good, checked the line and while they didn't find a fault, reset it and the broadband came backup.
That's all really good and a huge improvement on previous problems.
However, I have spend a lot of time previously on this forum working with moderators to get the SNR set to a level that provides a very stable, but slightly slower connection ~12Mbps - 9dB i think was the number it was set at.
I suspect the reset of the line may have changed that as we are now getting frequent dropped connections and much higher speed. Can this be checked, please?
Regards,
Keith
4 REPLIES 4
Message 2 of 5
Re: Frequent Dropped Connections Since PowerCut
can you please post your hub stats then we can help you further
keithdw
Message 3 of 5
Hi John, Is this what you need?
keithdw
Message 4 of 5
Or this? I notice uptime appears to be different...
Message 5 of 5
You now need to be able to show a stable connection for 3 + days then the moderators can be asked to arrange a rest
