johnboyjoe
Message 1 of 53
Getting a little tired of my connection being capped (non torrent traffic)
for example right now
Download speedachieved during the test was - 1.9 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Line state    Connected
Connection time    2 days, 08:45:04
Downstream    8,128 Kbps
Upstream    448 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Modulation    G.992.1 Annex A
Latency type    Interleaved
Noise margin (Down/Up)    11.9 dB / 31.0 dB
Line attenuation (Down/Up)    4.6 dB / 2.0 dB
Output power (Down/Up)    15.1 dBm / 2.1 dBm
Loss of Framing (Local/Remote)    0 / 0
Loss of Signal (Local/Remote)    0 / 0
Loss of Power (Local/Remote)    0 / 0
FEC Errors (Down/Up)    6694 / 16
CRC Errors (Down/Up)    3 / 2
HEC Errors (Down/Up)    3 / 0
Error Seconds (Local/Remote)    3 / 2
it happens every evening too, i can't even stream youtube video's in decent quality, i'm starting to get very sick/tired of this and want something done about it without the hassle of dealing with some Indian that really has no idea what they're talking about and reading off a script.
any idea how i can get this sorted out without to mush hassle?
thx.
52 REPLIES 52
Moderator
Moderator
Message 2 of 53
Re: Getting a little tired of my connection being capped (non torrent traffic)
Hi Johnboyjoe
Send me an email using the contact the mods link in my profile I can have this investigated for you.
Stuart
Message 3 of 53
is there any problems showing for your exchange? http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
johnboyjoe
Message 4 of 53
thx email sent, as for the exchange cheers for the links but its been going on for a while and its very noticeable, i use the PC and connection from 9am in the morning until 2-3am most days.
Message 5 of 53
The forum mods normally reply within 3/5 working days after you have contacted them
They will contact you personally by email or phone
johnboyjoe
Message 6 of 53
3/5 working days, really?
i was thinking something might happen a little quicker than that lol
latest test results done a moment ago:
 Download speedachieved during the test was - 2.21 Mbps
Message 7 of 53
yes you are i queue awaiting the mod teams help all mails they receive are dealt with strictly in turn
Message 8 of 53
I assume that you are doing these speed tests using an Ethernet connection and not wireless?
Message 9 of 53
your connection isn't being capped you appear to be suffering from possible exchange congestion which the mods will be able to look into for you this will be affecting others as well on your exchange BT do not cap speeds
johnboyjoe
Message 10 of 53
yes Keith i'm connected using the ethernet 🙂
"possible exchange congestion"
in other words to many people are connected/using the exchange at once?
"There are currently no known 20CN VP capacity problems on your exchange."
what does that mean?
thx.
latest test:
 Download speedachieved during the test was - 1.67 Mbps
