Do you mean
Getting disconnected from bt home hub 2.0
Basically I have the BT 2.0 hub and ever since the latest update I seem to be getting disconnected from the internet for about a second or two and because I play on Xbox live that creates a big problem for me because it disconnects me from Xbox live and I have to reconnect and this can take a few minutes and this can happen around about 5 times a hour at peak times and at other times it doesn’t happen at all can someone please explain what’s happening.
Recognised Expert
Re: Getting disconnected from bt home hub 2.0
Hi Andzee, Welcome to the Forums Smiley Happy
Are you connected to your Homehub via a Wireless or Wired connection?
Can you try and reset your Homehub? (Push the little red button with a ballpoint pen or a thin object).
I hope this hleps
___________________________________
Like this post? Give it a Star Smiley Very Happy. If this post answers your question, please Mark it as the Accepted Solution.
