Moderator
Moderator
Message 11 of 14
Re: Going round in circles getting my elderly/disabled father's line off a 1mb capped line (supposed
Hi @markie1,
I called the number you put on the contact form but had no answer.
The BRAS Profile is due to change from 2000 to 7150.
Upgrade Time Left(Hours) 1 Hours 35 Minutes
You should notice the change then.
DanielS
Moderator
Moderator
Message 12 of 14
Hi @markie1,
I've checked everything and I can see that the speeds have increased and the BRAS profile is now 7150 kbps instead of the previous 1000 and 2000 speeds.
It'd be good if you could come back and confirm this for us.
DanielS
markie1
Message 13 of 14
Hi,
My dad has asked me to thank for getting this sorted. He says it seems all good his end now.
I appreciate all your help in resolving this matter. Thanks !!
Smiley Happy
Moderator
Moderator
Message 14 of 14
You are very welcome @markie1 Smiley Very Happy
I'm glad he's happy.
DanielS
