waggy
Message 1 of 11
HUB 4 flashing green, no broadband
Hi
What does flashing green mean?, it will not reset to orange, BT india say there may be a line fault and will monitor for 24 hours, now they say an engineer wil call thursday PM, but will charge if it is my fault.
10 REPLIES 10
Message 2 of 11
Re: HUB 4 flashing green, no broadband
here is what like mean http://bt.custhelp.com/app/answers/detail/a_id/44266/~/what-do-the-lights-on-my-bt-home-hub-4-mean%3...
are you using test socket?
waggy
Message 3 of 11
It is like my broadband has been switched off, there is an order on my account I did not place, it will not let me view it, any mods able to have look incase someone cancelled my broadband....phone works fine.
Message 4 of 11
are you conencted to test socket with new filter to eliminate anything to do with your internal wiring
waggy
Message 5 of 11
Yes. all wiring checked, bypass main socket using filter, no improvement
Message 6 of 11
if you are in test socket with new filter and still no connection then you need to phone CS and report a fault
08001114567
Message 7 of 11
You could also try a factory reset of the hub that often resolves problems
waggy
Message 8 of 11
Hi
thanks for your help, the engineer replaced the hub 4, i now have only 2mbps, I had 3.5-4 mbps before, hub is not on latest firmware, does this look ok, I should be on ADSL2+
1. Product name:BT Home Hub
2. Serial number:+076270+NQ32335049
3. Firmware version:Software version 4.7.5.1.83.8.130.1.5.1.1 (Type A) Last updated Unknown
4. Board version:BT Hub 4A
5. ADSL uptime:0 days, 00:50:05
6. Bandwidth:827 / 2648
7. Data sent/received:13.0 MB / 253.6 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT FON:No
10. 2.4 GHz Wireless network/SSID:BTHub4-MT8K
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic / 1
14. 5 GHz Wireless network/SSID:BTHub4-MT8K
15. 5 GHz Wireless connections:Enabled (802.11 n 40 MHz (Recommended)) 20/40 MHz, WPS enabled
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic / 40
18. Firewall:Default
19. MAC Address:cc:33:bb:55:8f:58
20. VPI/VCI:0 / 38
21. Modulation:G.992.3 Annex A
22. Latency type:Fast
23. Software variant:-
24. Boot loader:-
BT Home Hub 4 (Type A) | Software version 4.7.5.1.83.8.130.1.5.1.1 | Last updated Unknown
Message 9 of 11
You are currently on adsl2
Can you enter hub manager then go to troubleshooting then logs and where the router connected to the internet you should see 2 lines with noise margin and connection speed - when you find them please post
waggy
Message 10 of 11
Hi
Thanks, here is the info
18:22:12, 15 May.( 105.230000) DSL noise margin: 6.00 dB upstream, 6.00 dB downstream
18:22:12, 15 May.( 104.320000) DSL line rate: 827 Kbps upstream, 2648 Kbps downstream
