Message 11 of 17
Re: Help, exhausted all possible options!?
Did you use Ethernet connection when you ran btspeedtester?
Message 12 of 17
Ping test via CMD (Not sure why I'm getting these results as I can connect to google fine at this point:
Pinging google.co.uk [2a00:1450:4009:806::2003] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2a00:1450:4009:806::2003:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Message 13 of 17
Yes all speed testing and results done via laptop connected to ethernet, via a BT Mini Connector. (FYI this has had no bearing on speedtests as on Wifi its almost exactly the same.
Message 14 of 17
Sorry but have you tried connecting laptop direct with Ethernet to hub and see if that makes any difference?  Power line adapters can reduce speed - I have firsthand knowledge of that and there is also forum posts as well
Message 15 of 17
I have not, but with the speed test I have run I am getting my expected speeds at this moment, so I fail to see the necessity?
Message 16 of 17
Great so speed ok now?
Message 17 of 17
Speed has been good as I have been running these tests during offpeak hours as a baseline as you requested. I will post updated speed test when the issue occurs.
