Hi again lovely people from bt forums
interleaving went back on after about 2 months of a stable fast line noise ratio is 6db and up 27db
requesting to lock it on to fast this time?
the mods were very helpful last time
thanks again.
Solved! Go to Solution.
Did you not post about 3 weeks ago with a problem which engineer said was a battery problem ? Has your line been stable since? Adsl stats?
yeah they fixed that, didn't noticed any difference tbh, stats are the same as before noise ratio etc just i disconnected 7 am this morning and it went onto interleaved, was up for more than 15 days stable
According to the mods interleaving can not be locked to fast, so good luck with that!
1. Product name: | BT Home Hub |
2. Serial number: | +068340+NQ35241472 |
3. Firmware version: | Software version 4.7.5.1.83.8.130.1.17 (Type A) Last updated 02/05/14 |
4. Board version: | BT Hub 4A |
5. ADSL uptime: | 3 days, 10:55:13 |
6. Bandwidth: | 448 / 8128 |
7. Data sent/received: | 367.2 MB / 2.2 GB |
8. Broadband username: | bthomehub@btbroadband.com |
9. BT FON: | Yes |
10. 2.4 GHz Wireless network/SSID: | BTHub4-JXQF |
11. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled |
12. 2.4 GHz Wireless security: | WPA and WPA2 |
13. 2.4 GHz Wireless channel: | Automatic / 1 |
14. 5 GHz Wireless network/SSID: | BTHub4-JXQF |
15. 5 GHz Wireless connections: | Disabled |
16. 5 GHz Wireless security: | WPA2 |
17. 5 GHz Wireless channel: | Automatic / 0 |
18. Firewall: | Default |
19. MAC Address: | 34:8a:ae:81:ff:8a |
20. VPI/VCI: | 0 / 38 |
21. Modulation: | G.992.1 Annex A |
22. Latency type: | Interleaved |
23. Software variant: | - |
24. Boot loader: | - |
07:31:09, 22 Jun. | (168314.930000) DSL noise margin: 27.00 dB upstream, 6.20 dB downstream |
07:31:09, 22 Jun. | (168314.860000) DSL line rate: 448 Kbps upstream, 8128 Kbps downstream |
The mods will post a contact us link when they read this. From recent posts there is no 'lock' option.
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Hi James_lol,
Sorry about this, can you fill in the webform again and we'll take another look at this for you?
Neil
