Message 1 of 2
High Latency on World of Warcraft
Hi,
I've never had any trouble with my latency till today. Through the day, from 10am till 6pm, I have been trying to play with little success. Latency has been stuck at 1300ms and up to 3000ms for most of the day. I've tried switching from my powerline to a wireless adaptor to directly plugging in the ethernet into my computer. No difference in latency. Home latency is between 60 to 150ms. My server that i'm connecting to is Khaz'Goroth on US/Oceania. Why am i only seeing the problem today after being on the same server for years? Reset/speed test bla bla bla has been done. Am very frustrated.
Reuben
Trace route to server
Tracing route to 12.129.254.220 over a maximum of 30 hops
  1     3 ms     7 ms     6 ms  BTHomeHub.home [192.168.1.254]
  2    11 ms    10 ms    11 ms  217.32.143.32
  3    14 ms    10 ms    10 ms  217.32.143.62
  4    12 ms    11 ms    14 ms  213.120.163.50
  5    14 ms    11 ms    16 ms  213.120.157.74
  6    13 ms    17 ms    13 ms  213.120.157.182
  7    11 ms    35 ms    11 ms  acc2-10GigE-1-2-0.mr.21cn-ipp.bt.net [109.159.250.198]
  8    26 ms    26 ms    21 ms  core2-te0-12-0-4.ealing.ukcore.bt.net [109.159.250.135]
  9    24 ms    19 ms    20 ms  transit2-xe11-1-0.ealing.ukcore.bt.net [194.72.17.194]
 10    26 ms    21 ms    26 ms  t2c4-xe-10-0-0.uk-eal.eu.bt.net [166.49.168.33]
 11    23 ms    20 ms    20 ms  xe-9-3-0.edge3.London2.Level3.net [212.187.201.125]
 12    21 ms    34 ms    32 ms  ae-32-54.ebr2.London2.Level3.net [4.68.117.126]
 13    21 ms    20 ms    19 ms  ae-3-3.ebr1.London1.Level3.net [4.69.141.189]
 14    22 ms    20 ms    18 ms  vlan103.ebr2.London1.Level3.net [4.69.143.94]
 15    95 ms    89 ms   100 ms  ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
 16    93 ms    90 ms   100 ms  ae-81-81.csw3.NewYork1.Level3.net [4.69.134.74]
 17    92 ms    89 ms    89 ms  ae-3-80.edge3.NewYork1.Level3.net [4.69.155.145]
 18    95 ms    90 ms    91 ms  att-level3.newyork1.level3.net [4.68.63.142]
 19   158 ms   158 ms   159 ms  cr1.n54ny.ip.att.net [12.122.131.102]
 20   163 ms   158 ms   159 ms  cr2.cgcil.ip.att.net [12.122.1.2]
 21   163 ms   159 ms   170 ms  cr1.cgcil.ip.att.net [12.122.2.53]
 22   163 ms   159 ms   158 ms  cr2.dvmco.ip.att.net [12.122.31.85]
 23     *        *      163 ms  cr1.slkut.ip.att.net [12.122.30.25]
 24   183 ms   166 ms   163 ms  cr2.la2ca.ip.att.net [12.122.30.30]
 25   182 ms   176 ms   168 ms  gar29.la2ca.ip.att.net [12.122.129.241]
 26   157 ms   157 ms   158 ms  12-122-254-234.attens.net [12.122.254.234]
 27   161 ms   159 ms   159 ms  mdf001c7613r0004-gig-10-1.lax1.attens.net [12.129.193.250]
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:41:35
Downstream:8,291 Kbps
Upstream:1,267 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 6.0 dB
Line attenuation (Down/Up):35.5 dB / 20.4 dB
Output power (Down/Up):0.0 dBm / 12.6 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):
76 / 2
1 REPLY 1
Message 2 of 2
Re: High Latency on World of Warcraft
most likely server/ network congestion as the delays start outside the UK this is not a BT issue
