Moderator
Moderator
Message 11 of 11
Re: High upstream SNR/Noise margin? - slow speeds and pings going into the 1000s of ms!
Hi @MrDjP,
Thank you for taking the time to post back. I happy @JohnC2 was able to help improve your connection Smiley Happy
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
