mandsandaj
Newbie
Message 1 of 6
How on earth to I do something about the comically slow broadband I have (<2Mbps)
Any pointers?
Neighbours (<500m) have superfast
5 REPLIES 5
Message 2 of 6
Re: How on earth to I do something about the comically slow broadband I have (<2Mbps)
If you are a bt customer enter your phone number and post results. http://www.dslchecker.bt.com/
Post connection stats from your hub/router
oakserver
Message 3 of 6
If the reason is because you live far from the exchange or cabinet then moving would be one option.
If you were expecting higher speeds or the BT checker suggests that you should be receiving a higher speed then you probably have some kind of line fault that needs investigation. If this is the case then you need to log a fault with BT.
mandsandaj
Newbie
Message 4 of 6
Far from exchange....yes
No fault, just antiquated copper system.
Far from helpful response.....When am I going to be provided with fibre???????
Message 5 of 6
The only people that can answer your question is openreach
if you enter your phone number in the link I posted and then post results it will show what is available to you currently
are you a bt residential customer?
Moderator
Moderator
Message 6 of 6
Hi @mandsandaj ,
Welcome to the community and thanks for posting. If you can post the information requested by @imjolly we might be able to point you in the right direction.
Cheers
David
