Message 11 of 34
Re: Hub strange behaviour
while there is no real limit to how many devices you can have connected however using multiple devices at once may cause problems
Damo86
Message 12 of 34
Well I am connected thorough a filter now if is that what youi mean
Message 13 of 34
if you are now in the test socket can you post new router stats please
Damo86
Message 14 of 34
Sorry I think I didn't quite understand what do you mean by test socket
Message 15 of 34
test socket.jpg  this is the test socket behind bottom half of nte5 master
Damo86
Message 16 of 34
Connection Information
Line state:    Connected
Connection time:    0 days, 00:02:20
Downstream:    21.31 Mbps
Upstream:    1.164 Mbps
ADSL Settings
VPI/VCI:    0/38
Type:    PPPoA
Modulation:    G.992.5 Annex A
Latency type:    Fast
Noise margin (Down/Up):    3.1 dB / 6.2 dB
Line attenuation (Down/Up):    12.3 dB / 7.8 dB
Output power (Down/Up):    20.0 dBm / 12.1 dBm
FEC Events (Down/Up):    0 / 0
CRC Events (Down/Up):    0 / 0
Loss of Framing (Local/Remote):    0 / 0
Loss of Signal (Local/Remote):    0 / 0
Loss of Power (Local/Remote):    0 / 0
HEC Events (Down/Up):    0 / 0
Error Seconds (Local/Remote):    44 / 0
There is a red cable cut there it looks a bit messy, do you know what is it for,
Damo86
Message 17 of 34
Now it changed a bit
Connection time:    0 days, 00:06:54
ADSL Settings
VPI/VCI:    0/38
Type:    PPPoA
Latency type:    Fast
Noise margin (Down/Up):    3.0 dB / 6.2 dB
CRC Events (Down/Up):    1 / 0
HEC Events (Down/Up):    3 / 0
Error Seconds (Local/Remote):    45 / 0
Message 18 of 34
your stats look good with few errors.
I have tried to find a previous post with a problem similar to yours as I am sure CL Keith suggested a solution
Message 19 of 34
"There is a red cable cut there it looks a bit messy, do you know what is it for,"
not  sure what you mean by a red  cable
Damo86
Message 20 of 34
I was reading a post where another guy had an issue not sure if its the one you're saying. but this guy had to reset hub every 4 days or so..then this keith said that this could be due to router overloading while using wifi..
and John, yeah just like the one going into the little terminal, but red colour,its just loose. I guess if my phone and router  works then that's fine. I took a few pics of the socket, if you are interested to see them I can put them on..
Thanks!
